1990 Hp 465
Old 05-13-2005 | 06:59 PM
Default 1990 Hp 465
I have read about all about the valve spring problems on the HP 500's. I have a 1990 HP 465, shoould I have the same conserns. I am clueless, witch heads do I have? What are my potential problems? What machining can be done, and what should I expect? If I only do a valvejob what should I replace, and with what? I am not rich but would like to stay on the water...
sibleymoon is offline
Old 05-15-2005 | 03:53 AM
Default Re: 1990 Hp 465
The hp465 uses a flat tappet cam and the spring pressures are not as high as the hp500 with the roller cam. It won't be as much of an issue, but the cam is still pretty big for a flat tappet(.560/.578) I would think you should have the springs at least checked in the 200-300 hr range. It also depends a lot on how hard it has been run.
supercobrajet
3
09-13-2008 08:40 AM
MOERON
3
07-31-2007 10:23 PM
Cigaretteman
02-05-2005 08:44 AM
CMC
Superboat
3
11-03-2004 03:02 PM
CMC
10-18-2004 05:11 AM
