(truck) noisy rear end >
Old 03-07-2004 | 01:03 AM
Steve_H
Default (truck) noisy rear end
feels and sounds like the rear end is ready to go out.
when driving slow and turning slightly i here gears clunking and rear end binding. wierd part is it only does it after ive run it for awhile (30 miles on highway). removed rear inspection cover and everything looks fine. no metal in lube , gears looked ok.
99 dodge 2500 4x4 360 gas w/high miles
Old 03-07-2004 | 06:37 AM
Limited slip differential?
BadDog is offline
Old 03-07-2004 | 06:43 AM
If you have posi or limited slip use pennsoil gear lube it already has additive in it
brian41 is offline
Old 03-07-2004 | 07:11 AM
Steve_H
yes its limited slip
Old 03-07-2004 | 07:43 AM
birdog's Avatar
Yep..Drain it, Put the L.S. additive in & drive in fiqure 8s
to loosen it up.
birdog is offline
Old 03-07-2004 | 09:35 AM
traviss's Avatar
It needs the additive ( whale oil). My dads truck was doing that. Drive down the freeway for a while and when you go to get off and start turning, the tires would bark, chirp and the rearend would grind. We put some limited slip additive in it and problem solved
traviss is offline
Old 03-07-2004 | 09:37 AM
mcollinstn's Avatar
Use the separate bottle of additive instead of the lube with the additive already in it. That way you can keep adding till its better.
As far as driving 8's. I usually leave one wheel on the ground and run it in reverse at idle for a minute - then swap wheels on the ground and do the same.
mcollinstn is offline
Old 03-07-2004 | 10:11 AM
I had a a truck at my shop 2 weeks ago with a similar noise. I went through the same steps as previously mentioned. Still had the noise, but only when turning. It ended up being the trany mount. When there was a load, as in turning, the tranny would shift over making the u-joint bind, sending the noise down the drive shaft to the diff, making me think it was the gears or posi unit. Good luck!
Andy is offline
Old 03-07-2004 | 10:23 AM
Steve_H
well that was way to easy
added 2 tubes , went for a 30 ride , problem solved!
thanks a bunch guys
Old 03-07-2004 | 04:34 PM
With limited slip you want to keep up on the oil changes. I would replace the gear oil at your next convenience. Do use the additive and not the type with LS additive already in it.
BadDog is offline
GLH
06-27-2006 03:14 PM
VelocityMark
03-28-2003 02:16 PM
kevin225BR
04-04-2002 06:08 PM
