1/2" drives toe out >
1/2" drives toe out
1/2" drives toe out
Old 04-15-2004 | 11:03 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
Default 1/2" drives toe out
Is that too much? Been searching and find straight to 1/8 seems to be the census, but toed in.
toe out= props closer than drives leading edges??
'99 32' stepped hull, props now spinning out for manuverabilty.
US1 Fountain is offline
Old 04-16-2004 | 12:05 AM
cuda's Avatar
I was told 1/4 in.
cuda is offline
Old 04-16-2004 | 06:53 AM
Payton's Avatar
Charter Member #927
I thought I heard different boats like different settings. A 1/2" sounds like a lot. Experiment a little.
Payton is offline
Old 04-16-2004 | 07:08 AM
OldSchool's Avatar
Default Re: 1/2" drives toe out
Jerry,
It's been my understanding that if your props are spinning out, you would set the toe in and the torque offsets it. If the props are turning in, you would toe out.
I'm certainly no expert, but I just happened to read that in Powerboat when I was on the crapper last night.
OldSchool is offline
Old 04-16-2004 | 07:43 AM
BillR's Avatar
OSO Moderator
I just adjusted mine to 1/16" toe out. (props closer than leading edge) It was almost 3/4" toe in stock. Boat handles better now, and "maybe" a touch more top end.
Tried them at no toe, and boat had an odd feel to it.
BillR
'00 Scarab Sport 302 CC
'02 Cigarette Top Gun TS
'02 PQ 340
'00 PQ 280
'98 Scarab 22
'97 Baja Outlaw 20
'72 Checkmate
'65 Glastron
BillR is offline
Old 04-16-2004 | 04:39 PM
Ginger or Mary Ann?
Default Re: Re: 1/2" drives toe out
Originally posted by craig223
Jerry,
Ahhh, the home library. Thanks for the visual.
Also, mine is drilled and has a set screw to lock the adjustable end down to the rod, this in addition to the lock nut. Is this general practice? Seems overkill.
Thanks All
Old 04-16-2004 | 04:58 PM
later's Avatar
Default Re: Re: Re: 1/2" drives toe out
Thanks All
fountain sent a letter out in the fall of 98 i believe stating that they had poblems with the tie bar loosing up and this was there remedy, i took my boat to the dealer and the drilled and tapped and installed a set screw at fountains expence
later
later is offline
Old 04-16-2004 | 09:35 PM
1/8" toe out.
Back4More is offline
Old 04-16-2004 | 11:08 PM
merlin540
1/8 toe is correct
Old 04-18-2004 | 01:27 PM
Ginger or Mary Ann?
Default Re: Re: Re: Re: 1/2" drives toe out
later
I don't think so Tim.
If both tie rod ends are secured in the drive end caps, how can it possibly loosen up any? Only way to adjust the length is for the adjustable end to screw in or out. And that requires the large bolt to be removed from the drive cap. Fountain is all screwed up on this one.
Thanks though.
