Kpm Racing Raw Water Impeller >
Old 06-16-2005 | 04:21 PM
Monty's Avatar
Default Re: Kpm Racing Raw Water Impeller
I used anti-seize.
Monty is offline
Old 06-16-2005 | 04:24 PM
p4-33's Avatar
perty much covers the gamut.
p4-33 is offline
Old 06-18-2005 | 07:51 AM
Mr Gadgets's Avatar
Charter Member #601
Fred,
I ask again....
My Merc pump has the back of the housing with 90* fittings that point downward to clear my Stef's Oil pan. Do you have a solution for that?
Dick
Mr Gadgets is offline
Old 06-18-2005 | 09:54 AM
26ZX Donzi's Avatar
Trying to install mine right now and having same issues. Did you guys use the stainless wear plate between new pump and pulley housing? If you were to do it again would you drill out like ..Lightning did or try to cut and drill like P4 did?
26ZX Donzi is offline
Old 06-18-2005 | 10:31 AM
I remember having some of the same minor issues when I installed mine. I ended up rotating mine to an angle that fits, which required drilling new mounting holes. Not precision machining, but some trial and error. It clears my mechanical fuel pump and my gil oil pan and still has enough adjustment to remove and tighten the belt. So far mine has worked great!
Craig
WETTE VETTE is offline
Old 06-18-2005 | 11:59 AM
p4-33's Avatar
Originally Posted by Mr Gadgets
Fred,
I ask again....
Dick
Dick, I have both a straight fitting (output) and a 90deg fitting (input) on mine. Fred sells these, and they are some very pretty stainless hardware pieces. I'm pretty sure the pump housings have 1 1/4" NPT (maybe 1 1/2"?) threads, so your local plumbing should be able to set you up with brass, too.
Brian
p4-33 is offline
Old 06-18-2005 | 07:50 PM
outriggers's Avatar
Did you guys use the stainless wear plate between new pump and pulley housing? QUOTE]
What have you guys done? Doug
outriggers is offline
Old 06-18-2005 | 09:15 PM
26ZX Donzi's Avatar
Same question?
Old 06-19-2005 | 12:40 AM
  #31
Mr Gadgets's Avatar
Charter Member #601
Any pics available on the 90* fittings?
Old 06-21-2005 | 12:06 PM
  #32
outriggers's Avatar
ttt
Old 06-21-2005 | 02:27 PM
  #33
Mr Gadgets's Avatar
Charter Member #601
I finally got the motor in the boat and mounted my seawater pump.. I took a pic.. will try to post later. I think I want one of these pump kits, cause the stock merc stuff wont work with my pan and mount..
I will post the pics and ask more questions... thanks
Dick
Old 06-21-2005 | 02:52 PM
  #34
p4-33's Avatar
Originally Posted by outriggers
Did you guys use the stainless wear plate between new pump and pulley housing? What have you guys done? Doug
Doug, sorry, but I didn't see that part of my install... my head was down in the bilge when the pump housings went together. I'll see if I can find out.
Anyone else with an answer?
Brian
p4-33 is offline
Old 06-21-2005 | 03:52 PM
  #35
Mr Gadgets's Avatar
Charter Member #601
Ok.. here is a pic.. well if it works...
My question is, with the 90* on the KPM pump will they make the down turn before they bump the motor mount?
In other words, how long is the pump housing and fittings combined??
If it will fit, I am ordering one!!
Dick
Old 06-21-2005 | 08:09 PM
  #36
outriggers's Avatar
Thanks Brian, I don't have my old one out yet but from looks of another housing and the new one, I don't think the plate is used. I should give Fred a call. Dick, Here is a pic with the old plastic housing and the new one with straight fittings. If you need any other pic's or measurements let me know. Thanks, Doug
Old 06-21-2005 | 10:35 PM
  #37
outriggers's Avatar
Fred, Thanks for the great service and answer. Dick, Sorry you can't see the ruler better. My old stock housing measures 2 3/16, the KPM is 2 5/8, both without fittings. The straight fittings Fred provides are longer than the ones on the plastic housing. You will have to talk to Fred about the 90's. It sure looks nice, No comparison with the plastic. It's kinda a shame nobody will see it ,but I'll know it's there. Doug
Old 06-22-2005 | 04:55 AM
  #38
Mr Gadgets's Avatar
Charter Member #601
I hear you.. way down in the bilge like that, but you can sleep better at nite, right!!
Well Fred, can you tell me how much length the 90"s will add to that 2 5/8" measurement???
I just have the feeling that my present pump could give way and I dont have a back up.. Of course, as soon as I order it.. the old one will be upset and die just to spite me.. Shhhhhhhhhh.. dont anyone tell the old pump I am going to get him a new housing...
Dick
Old 06-22-2005 | 07:24 AM
  #39
p4-33's Avatar
Dick, you have a ton of room to use 90deg fittings. Freds fittings are (I'm guessing) only a 1/2" longer than the ones shown in your picture. If you can picture this... they have 1 1/2" or so in length of npt threads, (most of this ends up inside the pump) then 1/2" wide hex shoulder to get a wrench on, then the straight 90 (no sweep) behind that. They are polished stainless, and are nice looking pieces. No one will ever see them, but as Doug says you'll know they're there.
I'm kicking myself in the azz for not taking pics of my finished install, and I've tried to stand on my head to get pics of them in my boat. But my fuel system is blocking the view.
Brian
p4-33 is offline
Old 06-22-2005 | 12:38 PM
  #40
Mr Gadgets's Avatar
Charter Member #601
Hey,
thanks Brian.. thats what I wanted to hear.. I will get one on order...
Dick
Old 06-26-2005 | 10:40 AM
  #41
Mr Gadgets's Avatar
Charter Member #601
Fred,
The pump was there when I returned from boating on Friday.. Took a good look at it today during breakfast.. LOL! What a beautiful piece..
One thing.. I tried to screw in the two 90* fittings.. it was a no go.. holes are too close togther... I have some ideas. I will give you a call on Monday..
Dick
Old 06-26-2005 | 05:09 PM
  #42
Mr Gadgets's Avatar
Charter Member #601
Yes.. shorter ones will work. I thought about cutting these, but then you loose the ridge that helps hold the hose..
I am thinking the fittings that Wette Vette has on the back of his.. If I had one of those I could screw one in and bolt the other on. They would be offset a bit but who cares.. it has enough beauty to carry, we just need the functional part...
Dick
Old 06-27-2005 | 04:31 PM
  #43
Mr Gadgets's Avatar
Charter Member #601
Hey Thanks Fred!! I will check it and send back the others..
Dick
Old 06-29-2005 | 12:02 PM
  #44
StrikinLightnin's Avatar
p4-33
Bolted up the frount motor mount and found that I'll
have to do a little air-arc on the mount in order for
the hoses to fit.
No big deal.............
StrikinLightnin is offline
