IMCO Extreme SC drive.... >
Old 01-17-2003 | 06:40 AM
KAAMA's Avatar
Back4more,
All I would need are the EMPTY cases and the -2" vertical shafts. I'm 90% sure I have a line on a pair right now, but I will definately consider yours if the my deal doesn't work out. Thanks.
KAAMA is offline
Old 01-17-2003 | 05:03 PM
OK...These have the 1.34 gears and the 1 1/4" propshafts.
Back4More is offline
Old 01-17-2003 | 07:44 PM
Tinkerer's Avatar
In regards to the loss of using the stock mechanical spedo. I plugged the hole at the bottom of the spedo pick up passage and drilled the speedo hole into the front of the drive and it works fine.
Tinkerer is offline
Old 01-18-2003 | 07:09 PM
28Eliminator's Avatar
Tinkerboater. where is the passage located? Is it in the low water pickup. What did you plug it with and where did you drill the hole. I have the IMCO shorty and xr upper so the passage isn't used.
28Eliminator is offline
Old 06-26-2005 | 11:15 AM
Default Re: IMCO Extreme SC drive....
Hi I need guidance on driving and not breaking a Imco Extreme SC drive.......what are the can handle and can not handles ?
The boat is a 25 Talon with a blown 557......aprox 950 hp .
Thank you .
Larry
larrybowen is offline
Old 06-26-2005 | 09:43 PM
950hp?????
Its just a question of when it will explode????? I would keep a spare handy.
Old 06-26-2005 | 09:59 PM
Dock Holiday's Avatar
Charter Member #34
Originally Posted by GETTINBYE
IMCO,
Any experience with a version of your shorter drive on a Baja, 36 Outlaw? If so how much shorter 1" or 2" & what were the results?
Mark
If you go to the Baja section you will find some information on this.
I have a buddy that put the 2 inch shorties on some Whippled 509's running 94 MPH and they did very well.
Another guy put them on a stock boat and he could not get it on plane.
For some reason I cannot explain they do not work well on the 36 with stock power. If you put the extension boxes on it will help them to work better.
Dock Holiday is offline
Old 06-26-2005 | 10:19 PM
MIKEHTMSR24's Avatar
Hey Dock, it's Mike with the black HTM. Actually the 36 with the Whipples had one inch shorties on it.
He didn't have a bunch of hrs on the drives b4 he sold it. So the verdict is still out.
I do have a buddy that has a 620 ci in 830 hp 25 eliminator with a 250 shot of NOS on it and it lasted pretty long. But it wasn't a blower motor.
950 blower hp is a ton on a drive. So my opinion it's just a matter of time. I would go and get the 4X4 if I had that can of power
MIKEHTMSR24 is offline
Old 06-28-2005 | 08:53 AM
MikeBaja232
I'm currently running a Bravo XR with 1.36 gears on my 25 Outlaw. I've got a line on a used, less than 15 hours, Imco Extreme outdrive with the same ratio. Any opinions on what each is worth? Anyone interested in the Bravo XR?
Mike
Old 06-30-2005 | 11:11 PM
Mike
mike from Corydon, IN but now in SC
Is it a Imco Extreme or a Imco Extreme SC big difference
not much if any between an XR and a Imco extreme
what blade are you swingin
