28 Sit Down ??
#101
The chamber in a bravo by the upper gear set does it play a role in cooling the drive and has any one not run water through the drive Im going to a through hull pickup and wont be useing the pickup in the drive anymore .or could you use both?
#102
I have a hull pick up on my boat for the engine. The water that enters the drive pick up runs into another hose and dumps out the side of the boat next to the bilge pump dump. It was like that when I got it. If I were to do it myself, I would mount a dump for the water so it dumped out right on top of the drive and worked as a drive shower.
Since the water was just flowing through the case, I had the water jacket on the upper case drilled and tapped. I'm running braided line to my drive shower from there.
#105
Originally Posted by B-Stubb
I cdnuolt blveiee taht I cluod aulaclty uesdnatnrd waht I was rdanieg. The phaonmneal pweor of the hmuan mnid Aoccdrnig to a rscheearch at Cmabrigde Uinervtisy, it deosn't mttaer inwaht oredr the ltteers in a wrod are, the only iprmoatnt tihng is taht the frist and lsat ltteer be in the rghit pclae. The rset can be a taotl mses and you can sitll raed it wouthit a porbelm. Tihs is
bcuseae the huamn mnid deos not raed ervey lteter by istlef, but the wrod as a wlohe. Amzanig huh? yaeh and I awlyas thought slpeling was ipmorantt.
#108
Thanks man....that made my day.
Kind of bumming out at work right now.
Then I read your post and pictured humans bouncing around in your cockpit in lawn chairs at 90+ mph...
Mad me laugh...
Good luck with the waiting...
Mad me laugh...
I will come by and see it in person last part of April.
