water pump hose? >
water pump hose?
water pump hose?
Old 04-06-2005 | 09:33 PM
Default water pump hose?
undefined I have a 1996 mercruiser 502.In the process of winterizing the motor, I pulled off the inlet water hose from the outdrive to the water pump and the outlet hose from the pump to the oil cooler. I went to reinstall last weekend and i'am not sure if inlet connects to the bottom of the water pump or top?
mike floyd is offline
Old 04-06-2005 | 10:40 PM
Scott's Avatar
Charter Member #30
Default Re: water pump hose?
The one with the X if you have the same pump.
I have Steps & Bubbles!
Scott is offline
Old 04-07-2005 | 05:39 AM
My reg old pump has the outlets faces straight back. The top is the output to the cooler,the bottom is the suction hose(ruff wrapped appearance) that goes to the outdrive.
cooltoys61 is offline
Old 04-07-2005 | 05:41 AM
Top
SkiDoc is offline
Old 04-07-2005 | 12:53 PM
I've got mine coming into the bottom and have 30+PSI on both motors?
Old 04-07-2005 | 08:37 PM
It is possible to mount the pumps rotated so the outlet can be up or down look at the back for left out that is the outlet port hard hose is the suction to transom or sea strainer soft hose is outlet to coolers
fstboater is offline
Old 04-08-2005 | 12:16 PM
Good point,and bring a mirror and flashlight. They will say "inlet" and "out".
hurleyr
8
04-15-2008 09:26 AM
onesickpantera
05-18-2006 10:44 AM
DrewDown
1
03-13-2006 10:35 PM
509 SC
4
04-03-2005 11:27 AM
32fever
6
08-14-2002 03:11 PM
