My HP 500 EFI Whipple motor made 903 ft/TQ and 839 HP
#41
Re: My HP 500 EFI Whipple motor made 903 ft/TQ and 839 HP
Originally Posted by OldSchool
LMAO!!!
By the way, thanks for letting me assemble Mashers engine last friday. I really wasn't as phucked up as you all thought I was!!
#43
Originally Posted by satisfactionII
Very very Nice, and I bet they sound awesome.
If I had dry tail pipes The Whipple blower whine is a lot louder that my old Scarab w/ the littlefields .
Here is a shety clip with buddy driving up to about 5500rpm and me trying to Video it
http://media.putfile.com/Hustler-Whi...eo-7-24-05-040
#44
Something cool to wake up to, how fast were you going there.
#46
Geronimo36
LMAO!!!
Nice clip, gotta love blowers!
#48
Jassman: This is Rob's thread so I'll be brief. The dyno numbers (with 7 psi pulleys) are comparable enough to point out the charateristics of the two different blower designs. On one hand we did not run accessories and the headers were Mark's sport tubes; on the other hand we used stock heads and cam and did not rev over 5500 RPM. These variables prevent an absolute comparison but the short answer is: screw compressor will make more down low, centrifugal compressor will make more up high.
RPM Rtech Whipple
3500 458 520
4000 574 615
4500 664 685
5000 740 726
5500 803 762
6000 ------ 779
Hey Rob: I've been looking over your installation pictures again. They demonstrate the meaning of the word "blueprinting". Be careful though, attention to detail can sometimes lead to OCD!
RPM Rtech Whipple
3500 458 520
4000 574 615
4500 664 685
5000 740 726
5500 803 762
6000 ------ 779
#49
RPM Rtech Whipple
3500 458 520
4000 574 615
4500 664 685
5000 740 726
5500 803 762
6000 ------ 779
RPM Rtech Whipple
3500 458 520
4000 574 615
4500 664 685
5000 740 726
5500 803 762
6000 ------ 779
#50
Strip- Great job-turning props in or out. What gear, what lower, crescent or standard.What trim setting and tabs.
#51
Strip,
Info if it helps you any,
2003 388 with ITS 1.5 Gear Ratio Sportmaster Lowers 500EFI's with Whipple's
34' four blade Merc props
105 GPS and still climbing..........
Louisiana Run on Pontrain Cool Fall Air
VeeCat
VeeCat
#52
Strip,
This boat also has a Westerbeke Generator and Air, slight drag from the water inlets for these.
VeeCat
VeeCat
#54
Originally Posted by VeeCat
Strip,
VeeCat
VeeCat
It has the Bmax 1.30 gear 28 p 4blade B1 prop,turning props out ,no bow lift now,tabs -1/2.drives at +1or 2.reg bravo on foot low water pickup,I just bought some 30P should beable to turn the 6000k
fast fun 2 ...at 7 psi it was 779hp
#55
Strip,
I don't have your email address so I will leave you mine
boatmail is the first part the at sign then charter dot NET. Something about spammers is why I am writing this way.
I did notice in running this boat that you must keep your tabs at least level or a touch in. Bringing them all the way up does not work on this slick, FAST hull. Do whatever you want with the drives as far as raising until you get max speed no problem. Remember on a stepped hull not to lower into the negative trim area with the drives. But correct Tab is critical. At least in my seat time. These boats must have some bird in them,
Because they FLY!
Over 100 mph with gen/air/TV/DVD and complimentary HUSTLER PORN.
VeeCat
Because they FLY!
VeeCat
#56
Strip,
Because they FLY!
VeeCat
Because they FLY!
VeeCat
#57
RPM Rtech Whipple
3500 458 520
4000 574 615
4500 664 685
5000 740 726
5500 803 762
6000 ------ 779
RPM Rtech Whipple
3500 458 520
4000 574 615
4500 664 685
5000 740 726
5500 803 762
6000 ------ 779
#58
Originally Posted by Jassman
Just trying to find out what the difference is between the two, which was explained in your comparison. Thanks. I have 3.3 Whipples, different block though. Jeff
Jeff hows your project going????
#59
#60
Waiting for TMP to get back to me. I speak with Eddie once a week, parts are back except for the Whipples.
#61
So far. I just sent The B-Maxs back to Dean at the Bravo Shop . I am getting him to ck them out and I am trying to change to his new style foot maybe that will help some , Cant hurt
#62
Originally Posted by articfriends
Does the new style lower your talking about have gears stronger than stock xr gears,I'm still exploring my options for this upcoming year,Smitty
I have about 275 hours on my Bmax's and have never had a HP or TQ related failure . Dean said he has never seen his upper fail.
The Bravo Shop costumer service has been outstanding /fast Dean has always taking care of me..
Smitty call and talk to him ,he will shoot ya straight
#63
How the new boat comming? you going to be running this summer
#64
Trying to finalize, 22k apart, Im ready.
Here are the plugs . Its was safe/fat
Did a leek down before I tore it down ,there soso
#65
Well so far so good.I tightened up the ring gaps and higher boost now its making a little more power it does seem stronger.Ill start a new thread with all the Dyno sheets. Waiting on my buddy Chris to send me the Video of the Dyno pull at 11.5 lbs of boost.That Whipple blower whine was making some noise
Just waiting on the new B-Max's
#66
Rob,I just re-read this whole thread,how many hours did you have on it from last season before refreshening it? Were the rings beveled or soft,I see you mentioned they looked bad. I ran my 540 135 or 140 hours last time before freshening and the rings seemed like they lost there strength when I was pulling them off the pistons like they had gotten soft. I did try running 11-12 lbs of boost though too without big enough injectors before rebuilding last time also which is probably what did the rings in. My timing chain also had pitting in the rollers. I only put about 40-45 hours on the 944 hp version of my 540 last year so I'm not freshening it this year,Smitty
#69
Tell me what you all think of the pick?
#71
I am guessing the dark color is from the overlap of the cam.What do you think????? Crane 741.Maybe blow thru?
#72
This is the bad thing about the Fel Pro Metal layer gaskets .. the black stuff is a beoch to get off the surfaces
#74
MarineKinetics
Rob,
Exhaust reversion on the intake side. There are multiple causes working independently or in conjunction with each other creating this condition. The spent charge is working its way past the intake valve back into the port/plenum area, concluding this is occurring during the IVO portion of overlap. As the piston rises during the exhaust cycle, expelling the spent charge (with your valve events), the intake valve opens @ 38º BTDC. Ideally, at this point, the intake column will have enough energy to initiate column motion; the exiting gasses have enough velocity to create a depression behind the exiting charge assisting the entering intake column. If the pressure differential of the combustion area > the intake port you have intake reversion. Soot.
Spring bounce would occur only at IVC where the piston is rising on the compression cycle with fresh charge in the cylinder. This would decrease charge trapping, VE, and cylinder pressure, without the soot deposits.
Your cam is advanced 5º on 107º ICL/112º LSA, however retarding it (on a ground cam) for a later IVO might not be the answer. This will retard the other 3 events at the same time quite possibly creating a whole new set of adverse conditions.
Causes can work independently or combination
Low intake port velocity
Low exhaust port velocity
Exhaust restriction
Early IVO, excessive overlap
Photo of reversion courtesy Larry Meaux
Bob
Exhaust restriction
Bob
#75
Originally Posted by rmbuilder
Rob,
Exhaust restriction
Bob
Exhaust restriction
Bob
So the Intake valve is opening to early letting in the spent charge containment the intake charge, passing each other in the intake runner? With this making the soot build up on the lower intake inlet. With This only happing at idle until intake port velocity builds up/ off idle and the whipple start pushing the air in
I figure the low intake port velocity (stock heads)and the Crane 741 cams excessive overlap contributed to this.So a better cam for the heads I have or a better set of heads would help this . but again this mainly happens at idle until intake port velocity pushes the charge in making the boom boom
Bob what is the difference in the overlap on my cam[741] over a similar cam that is made epically for a blower motor??
I guess thats why they say the stock 500efi cam works real good with a blower.
If I change the intake valve opening to later,also less over lap like normal blower cams I wouldn't bealbe to run the boost I am running ? But I guess the motor would make more power with less boost with a tighter cam???
This is making my head hurt I need a beer
#77
just put the motors in A Fountain and you will be well over 100MPH
Tom ya got yours running yet????
#79
[QUOTE=tomtbone1993]hell no still waitng on parts [/QUOTE
I'm still wainting myself for the marine mechanic to get his act together!
