Boat Wax, 1 coat per year???
I am interested in your opinions and experiences.
1. How often do you wax your boat?
2. How often do you wash it off?
3. Is it oxidized or turned yellow?
4. Is it kept under cover or in the sun?
Would you be interested in a product that brightens and/or brings back your graphics, clearcoat or gelcoat even if your boat is brand new or not? Last 6 months for boats kept in the sun 24/7 and lasts for 1 year on boats that get constant use, but are stored under cover? Applies easily, allows you to just wipe spider poop off with a towel? Contains no CARNAUBA so it won't turn your boat yellow? Has been hand tested personally on hundreds of boats. Works on all fiberglass, all plastics, all metals and leaves a "slick", High Gloss finish that lasts?
Re: Boat Wax, 1 coat per year???
Ill try it!To bad it doesnt turn the boat yellow though,I have a yellow boat that if left in the sun with out cover on it for to long it turns white Ill take some though!I clean my boat before and after every use and being 38 it takes some time! THANKS JUSTIN [email protected]
Originally Posted by berns29scarab
sounds like a frenzy product
"Unregistered Gun"
How good is it on taking water marks off the hull, for some reason my boat has a couple spots on the hull that are light light brown.
Originally Posted by OldSchool
Sounds like OSO BoatShield!!!!
