DIY:80's Formula Gauge Bezel Removal. >
Old 04-30-2007 | 08:18 PM
pshannon's Avatar
Default DIY:80's Formula Gauge Bezel Removal.
Hey guys here's a helpful DIY for anyone who want to take off there original formula gauge bezels and do what they so please.Mine are going to be smoothed and and painted candy red.More pics of that next Sunday...So here we go.
Tool:
1 Fillips Screw Driver Medium Size.
1 Deep Well 9/32nds Socket and Ratchet
1 Flat Head Screw Driver
1 Small Crescent Wrench
This is your basic 80's Early 90's Dash Layout.
Step 1
Start by using the philips screw driver to remove the 8 screws holding the panel to the dash.Circled Here
Step 2
Once you have removed the 8 screws,use the flat head to pry the panel away from the dash.Mine just came right off so I did not have to pry,but incase it doesn't pry gently.Should look something like this...
Step 3
Once you have the panel out,gentle pull it a little so you can lay it flat on the front of your dash.Then you need to use your socket and ratchet to loosen the 2 nuts on the back of the gauges.If you can't get the socket on the nuts use the cresent wrench to loosen them up.
pshannon is offline
pshannon's Avatar
Step 4
When you have loosend the nuts( do not remove),hold the front bezel with one hand while you turn the back of the gauge clockwise a quarter turn.Then pull the bezel striaght off.That's it,repeat step 3&4 for each gauge.Reverse step 4 when you put them back on.
This DIY is merely a guide to help you and I am in no way responsible if you break your boat....
pshannon is offline
Old 05-01-2007 | 08:42 AM
88formula223's Avatar
NO WAKE ENFORCER
nice work post pics when they are painted
88formula223 is offline
Old 05-01-2007 | 09:03 AM
pshannon's Avatar
Yup,painted pics will be up late sunday,and installed pics should be up monday....
pshannon is offline
Old 05-02-2007 | 11:23 AM
thank you for the info!!!!!!!!!!!!!!!!!!!!!!
Car Biz is offline
Old 10-29-2007 | 09:54 PM
pshannon's Avatar
Finished Pics:
Sanding:
Priming:
Primed
Done:
Installed;
pshannon is offline
Old 10-29-2007 | 09:55 PM
pshannon's Avatar
pshannon is offline
Old 10-30-2007 | 04:11 AM
looking great.nice work
maelstrom is offline
Old 10-30-2007 | 05:26 AM
WoW that came out great, nice touch
88242LS is offline
Old 10-30-2007 | 01:45 PM
NO WAKE ENFORCER
nice!!!!
CelticPride
5
03-20-2023 12:23 AM
jackhammer
2
04-20-2005 09:29 PM
Boomer 880
7
02-08-2005 08:18 AM
WETTE VETTE
Baja
10
02-17-2002 11:08 AM
Croozin2
01-25-2002 09:20 AM
