Props inward or outward????on a Fountain >
View Poll Results: Prop Spin??
Inwards
23
82.14%
Outwards
5
17.86%
Voters: 28. You may not vote on this poll
Old 07-11-2007 | 01:53 AM
tomtbone1993's Avatar
Default Props inward or outward????on a Fountain
Rcolter and myself have been in deep discussion over this issue.
My vote is outward to get the boat out of the water.
How do you run yours?
tomtbone1993 is offline
Old 07-11-2007 | 05:23 AM
INDY27's Avatar
My props turn in, no problems docking .
AUTOCONNECTIONLLC.COM
INDY27 is offline
Old 07-11-2007 | 06:17 AM
jryan26's Avatar
Ive always heard in lifts the back of the boat.
jryan26 is offline
Old 07-11-2007 | 09:29 AM
INDY27's Avatar
Reggie says spin them in!
INDY27 is offline
Old 07-11-2007 | 09:45 AM
http://www.offshoreonly.com/forums/s...highlight=spin
Rcolter is offline
Old 07-11-2007 | 09:48 AM
Rcolter is offline
Old 07-11-2007 | 10:20 AM
This thread says to spin out on not stepped boats, for MPH. I shall review the other one........A stepped boat like they are reffering too is deep steps, not the little ones on our old buckets
Old 07-11-2007 | 10:25 AM
On Time's Avatar
Tom,
Mine turn in. The docking is harder because you have to use some throttle and steering but I'm getting used to it. We played with a different boat in Austin (38 Scarab) one day turning the props in then out and when they were turning in the bow lift was too much which really dug the transom in on that boat.
"Teague on Tech" 7/11/02: "I would definitely try swapping the drives and turning the propellers inward. I can almost guarantee that the boat will have a higher top speed with the drives turning in because there will be more bow lift and less wetted surface. You need to be aware that the boat won't be as easy to manage around the dock with the propellers turning in."
"Teague on Tech" 12/04: "If the boat balance requires more bow lift, Bravo One four-blade propellers turning in would be the most effective. And, if it is determined that more transom lift will do the job, Hydromotive four- or five-blades turning out would provide the maximum transom lift. A combination of propeller rotations with each propeller selection will provide varying results. On your boat, outward propeller rotation will provide transom lift, and inward rotation will provide bow lift. Maneuvering around the docks is easier with the propellers rotating out."
On Time is offline
Old 07-11-2007 | 12:18 PM
Except for the older straight bottom boats, every Fountain I've been around turns them in....
jmeng is offline
Old 07-11-2007 | 12:28 PM
That is what we own
