Best way to lift boat off trailer >
Old 01-29-2008 | 11:09 PM
LubeJobs42's Avatar
Default Best way to lift boat off trailer
I need some ideas. I keep the Mercedes boat on the tilt trailer at a Benz dealer. Since I can't put that trailer in the water, I have to have someone lift the boat off the tilt trailer and either put it in the water or on my aluminum traier so I can launch it myself. it is a major pain and expensive to have a marina do this. Hauling both trailers to and from the marina alone is a chore. I have one 4 ton hoist in my warehouse and was thinking of getting another so i can hook lift straps to the boat, lift it and switch trailers. Anyone have any other ideas? I looked into Yardarm lifts but they are $5k for the set and extremely heavy and near impossible to transport. The boat weighs just under 10k lbs.
LubeJobs42 is offline
Old 01-29-2008 | 11:25 PM
JasonSmith's Avatar
Dumb me, but why can't a tilt trailer go in the water? Is it just salt water it needs to stay out of? If so, I get it.
JasonSmith is offline
Old 01-29-2008 | 11:27 PM
PLEASE DON'T DO IT YOURSELF!!!!!!!!!!!!!!!!!!!!
I can just see a bad luck post coming.
Old 01-29-2008 | 11:29 PM
Pretty sure its probably the salt issue. I have seen tilt trailers used to put boats in/out at LOTO.
Old 01-29-2008 | 11:31 PM
Bling Bling
I thought that was your boat in front of the Mercedes dealer in Lauderdale. I was there two weekends ago and when I came around the corner it looked way kool in front tilted and in front of in my opinion the best cars made.
I thought I've seen some houses on the water untill I viewed some of the cribs on the Inter Coastal in Lauderdale. WTF do you do with a 35000 sq ft house, and tied up outside is a 125 ft yacht.
After boating in FL the last 2 years, I've learned that it's a great reality check when you think you got money.
Good luck with the hoist problem.
blingbling is offline
Old 01-29-2008 | 11:51 PM
LubeJobs42's Avatar
I'll be careful
Yes, the salt is why I won't dunk it.
Old 01-29-2008 | 11:52 PM
Lofty's Avatar
Gino, we use a couple of "A" frames on rollers. I've lifted up to 20k lbs wit htis rig. We have chain blocks, 2 stern and 1 bow. It should give you more than enough room to pull the trailer out without striking the forward "A" frame.
Lofty is offline
Old 01-29-2008 | 11:55 PM
JasonSmith's Avatar
So, I'd be moving to fresh water.
Old 01-30-2008 | 07:30 AM
txriverrat2001's Avatar
Damn - Wish I had your problems Gino.... mice in the Lambo .. how to get my MTI off my tilt trailer ... etc.. LOL!!
txriverrat2001 is offline
Old 01-30-2008 | 07:40 AM
Tell ya what - I'll tell the Mercedes dealer to kiss my butt and move down there with you and handle any problem you consider to be a "pain in the butt" - for a small fee - and I get to drive every once and a while.... LOL!
After tackling the raw water pumps on those 850's in the NorTech - your stuff should be easy!
Good Luck!!!
