Weight of the older 30' s-types >
Old 02-27-2008 | 05:24 AM
Default Weight of the older 30' s-types
I am wondering if anyone has any idea what the mid 80's 30' s-types weighed in at? Any chance someone has an old spec sheet from back then. Mine has big blocks which were not a factory option but I already know the weight difference between small and big blocks so I am wondering what the boat weighed with small blocks. Any help would be greatly appreciated.
502ss is offline
Old 02-27-2008 | 06:31 AM
Jammin''s Avatar
It depends on how much water they've soaked up.
Jammin' is offline
Old 02-27-2008 | 12:14 PM
Rookie's Avatar
http://www.nadaguides.com/default.as...R&d=1600199878
Rookie is offline
Old 02-27-2008 | 02:49 PM
How accurate do you think that is? I am also assuming that is dry weight.
502ss is offline
Old 02-27-2008 | 03:16 PM
I used that weight for my Scarab and later took it to the scales and found it dead on.
Kims is offline
Old 02-27-2008 | 03:33 PM
Great! I will run with that then!
502ss is offline
Old 02-27-2008 | 04:53 PM
6500 dry
150x7=1050 gas + 200-400 for gear
puts it at just under 8000 wet (heavy)
Westcoast is offline
Old 02-27-2008 | 10:03 PM
Simply what makes it the best in the big waves.... It still is a lot easier to add power to an engine than to add strenght to a hull...
Kims is offline
Old 02-27-2008 | 10:23 PM
couldn't agree more.
scarabfun is offline
Old 03-04-2008 | 04:45 PM
Yes, thats correct 6400#...........
senzaspectre is offline
