Efi
Efi
doing some mods to my 598.
I bought the Holley smart coils and was thinking on going with a crank trigger and cam sensor instead of the dual sync distributor.
Are these the right parts
MSD cam sync and oil pump drive P# 85141
will this work with a tall deck?
Holley crank trigger wheel 36-1 tooth P# 556-113
or should I run the 60-2 wheel
eMSD cam sync and oil pump drive P# 85141, comes with a slip collar.rface with most afterHolley EFI systems and can easily interface with most aftermarket EFI systems. Chevrolet Model Features Melonized Gear and Adjustable Slip Collar for Deck Height Variations.market EFI systems. Chevrolet Model Features Melonized Gear and Adjustable Slip Collar for Deck Height Variations.
I run the 60-2 it supposedly gives slightly better idle with more precise crank position. Some drag race guys have had issues at high rpm with it though, my setup has been rock solid to 6400 rpms.
ATI makes some built in trigger wheels..
ATI - Crank Trigger Shells
Would this be a better option so pulleys belts and such don`t have to realigned due to the extra wheel?
