Daytona sensors ignitions, distributors, plug wires..
Pro Billet Dizzy. Both units identical even have the same model number.
caps are new 2018, not rusted, been treated with anti corrosion marine inhibitor. Come with spark plug wires.
Terminals set up for Daytona sensor ignitions. May need new ends if not used with Daytona.
$350 for both
Price includes (2) CD-1 Systems. (1) USB Harness kit. (2) map sensor harness kits.Instructions.
Unit comes pre loaded with a 3D timing map designed by the famous MILD THUNDER and perfected by yours truly for optimum safety and idle quality. If you`re supercharged (7psi) and want your engine to idle like a 500efi and last just as long this ignition is for you. If not then this comes with preloaded maps or make your own.
http://www.daytona-sensors.com/cd-1-...system---mari…
A Laptop set up with proper ports and loaded with the software can be purchased separately for a truly ready to run system ($200 additional )
Throw those crappy MSD boxes away and step up to trouble free boating.
$700 for all
Buy the distributors and Ignitions for $950
$350 for both
$700 for all
Its a sickness..........
Hopefully no thread next season on tossing/breaking oil pump belts!
