NGK BR6FS Socket Size
Needing to know if this is a standard size or smaller like 5/8. If it is standard anyone know a cross reference for the BR6FS. I have the Stainless Marine manifolds which make it about impossible to change the plugs without removing the manifolds. I heard that with a 5/8 plug I won't have any problems. I am able to get a 5/8 socket in there to change the plugs where I can't with a standard size. I got a 502.
Yea but you should always go straight on with a plug. Being off can break the porcelain or worse crack it without you noticing. If you find the rubber center too tight spray WD-40 in it and it will slip on and off easier but for goodness sake don't remove it.
Roby
Roby
Roby
Roby
