Kpm Racing Raw Water Impeller >
Old 03-17-2005 | 10:57 AM
gripit's Avatar
Default Kpm Racing Raw Water Impeller
Just bought the KPM Racing raw water impeller kit from Trick Marine. Looks nice and it guaranteed to run with no problamo for a year. They claim they can run dry for 24 hours! Anybody try them out yet?
gripit is offline
Old 03-17-2005 | 04:22 PM
Default Re: Kpm Racing Raw Water Impeller
I've got one and it works very well. It required some new holes in the bracket in order to work, but no big deal.
Attached Thumbnails Kpm Racing Raw Water Impeller-104_0499.jpg   Kpm Racing Raw Water Impeller-104_0500.jpg   Kpm Racing Raw Water Impeller-105_0501.jpg
WETTE VETTE is offline
Old 03-18-2005 | 01:25 AM
2112's Avatar
That doesn't look like the ones in their Hot Boat ads
2112 is offline
Old 03-18-2005 | 12:55 PM
StrikinLightnin's Avatar
Question Re: Kpm Racing Raw Water Impeller
The complete setup warrented for two years?
Is that correct Too Old?
StrikinLightnin is offline
Old 03-18-2005 | 02:10 PM
p4-33's Avatar
I've got a couple of these on the way, too. My current pumps have a bracket with a circular band that clamps around the neck of the pump, and a bolt at the bottom end to cinch it down. This allows for fine tuning of the belt alignment.
Is the neck of these pumps the same size and same diameter as a stock Merc raw water pump?
Brian
p4-33 is offline
Old 03-20-2005 | 10:02 AM
p4-33's Avatar
Thats a fine looking pump. My question is regarding the front side. Does the neck, drive shaft, and pulley come from my old pump? If so, I'm in good shape.
Brian
p4-33 is offline
Old 03-20-2005 | 10:49 AM
The pump looks really good. Whose impeller does it use? What's the cost for a pump with fittings,etc to swap out the Merc stuff? Thanks, Lou
Lmarth is offline
Old 03-21-2005 | 06:35 PM
Fred, On your web site I find 368-369 for $199 is that what I order for the one with the fittings as shown in the picture?
cobra marty is offline
Old 03-21-2005 | 09:13 PM
KPM told me that merc. impellers could be used as a second option in the pump. Don't know if that is code for they are the same impeller or not.
SkiDoc is offline
Old 03-24-2005 | 01:17 AM
Poorsche's Avatar
Globe Rubber Products makes a line of run-dry impellers--they claim 15 minute dry run time -- http://www.kfgi.com/nav.php?products_impeller
Poorsche is offline
