Go Back  Offshoreonly.com > Owners Forum > Sonic
2002-2004 sonic 358 ? >
Old 01-04-2004 | 10:34 AM
26sonic's Avatar
Default 2002-2004 sonic 358 ?
what top end speed will this boat run with 496 ho's ?
26sonic is offline
Old 01-04-2004 | 10:37 AM
LapseofReason's Avatar
around 75
LapseofReason is offline
Old 01-05-2004 | 03:43 AM
ash72201's Avatar
when you say 75 is that loaded or empty with no passenger's
ash72201 is offline
Old 01-05-2004 | 08:42 AM
It all depends on the water your in, flat or just the right about of chop, how loaded the boat is. Salt water or fresh water. Thats why I said around 75. One day you might have 4 people in it and the water is glassy the next it might have a 1.5 feet of chop. So 74 one time 76 the next. I dont know of any boat that hits the same mph every time. Look at the speeds in the kilo runs some of those guys are 5-8 mph off from run to run in the same day.
Old 01-21-2004 | 08:03 PM
Default Re: 2002-2004 sonic 358 ?
1/2 tank 2' chop 2adults 2 kids inland water xz drives 2003 24 pitch props 48-4900rpm
67mph gps 65 gps all day have NEVER seen over 69.
If I were to do a order again I would without a doubt
buy the HP 500 or hp525's
roadrunner is offline
Old 01-21-2004 | 09:54 PM
Test drove 500's 75MPH
Rippem is offline
Old 01-22-2004 | 05:14 AM
ash72201's Avatar
lapse of reason
not that i didnt believe you but i know of two 358 in my area that have 5oo, one with imco ext, xz drives good day 78-80 the other no ext76-78 i found it hard to undersand the 496's doing 75
ash72201 is offline
Old 01-22-2004 | 07:02 AM
Remember the 496 HO has 425 hp the 500's 470 HP so if you run the 496's hard you will still get a good mph out of them. You don't have near as much grunt in the 496 so when you have to get in and out of the gas it takes longer to wind it back up. If you are looking to buy you might want to think about a 31 with 496's or a 386 with 500's or bigger. I hear the 358 can be a little tricky to drive.
If I were buying a boat now and wanted stock power it would have to be 525efi's that is a great motor, then put Wipples on it later and you have almost 800 hp.
Old 01-22-2004 | 07:25 AM
Here is the test on a 99 358 so with the lighter layup now you see 1 or 2 more.
`shhttp://www.sonicusaboats.com/index_frames.aspould
Old 01-23-2004 | 04:52 AM
ash72201's Avatar
lapse of reason thanks for the info i tried accessing that site cant seem to find it as far as the difference in the 496 and 500 hp your right i want the cuddy of the 358 and the speed of my 26 it does 76 -80 again depending on water conditions. i have the 500 now and really like it but I'm looking for the warrenty of the 496 plus the difference in price between the two for only 90 hp. if the 496 with a xr drive will do 75 all day thats what i would go with. as far as super chargers i would love to put one on but nobody sells 91+ octane on the river where I'm at. so i don't want to be limited on where and how far i can go. thanks again.
ash72201 is offline
