Setting up a top gun >
Old 02-22-2004 | 11:32 AM
Von Bongo's Avatar
Default Setting up a top gun
1993 Top Gun..standard drives.
I have head the the X is pretty conservative. Anyone use shorter drives with any success?
Also I have seen both 3 and 4 blade props run. What are you seeing the best over all performance with and best overall top speed?
Von Bongo is offline
Old 02-24-2004 | 02:11 PM
Tbonepmp's Avatar
The Senior Charter Member #1070
Had a 94 Top-Gun with 600 Hawks and the 4-blade Hydromotives worked the best OVERALL. Both getting on plane and top end...
Regards
(What you see, is what you get!)
"Live every day to it's fullest for you give a day of your life to it."
Tbonepmp is offline
Old 02-24-2004 | 03:01 PM
later's Avatar
Von Bongo, my spare set of props are hydromotives 25's for bravoI if you would like to try them. let me know
later
later is offline
Old 02-24-2004 | 05:27 PM
Von Bongo's Avatar
Default Props
Hey!
Thanks for the offer, when it warms up a bit I will take you up on the offer!
I have been meaning to PM you so we can get together sometime when you are down at the lake. When you are going to be down for a few days let me know we can grab a bite of lunch or something.
Work - 573-348-2761
Cell - 573-434-9569
Home 573-302-2794
Talk to you later (no pun intended)
Mike Alford
Old 02-27-2004 | 03:46 PM
Von Bongo's Avatar
OK, not much action here, what about adding sportmaster lowers?
I would think with all the cigs someone would have done some experimenting with this and the X
Old 02-28-2004 | 06:38 AM
Biggus's Avatar
I'll be installing a pair of Konrad 540HP drives very soon. They are 1.5" shorter than my TRS. Sould be interesting, I'm going to try a pair of 5 blades too.
Biggus is offline
Old 02-28-2004 | 06:40 AM
Von Bongo's Avatar
OK, now we're getting somewhere. Are you replacing TRS drives of bravo drives?
Old 02-28-2004 | 07:35 AM
Biggus's Avatar
I'm replacing my TRS drives with the Konrad 540 drive
Biggus is offline
Old 02-29-2004 | 11:27 AM
Von Bongo's Avatar
Biggus, I am very interested in your results and how the installation goes. Please give an update when you can.
Old 02-29-2004 | 07:59 PM
P Offshore's Avatar
I played with X dimensions and extension boxes on several flat bottom (non stepped) hulls and did not get any better performance really. The best improvement was changing from TRS to Bravo and we went up 1/2" that seemed to work pretty good out of the hole and also good top end. One inch up I had too much prop slip hard to plane (lots of blow out) and less top speed by 2mph. Extension boxes and several X adjustments caused the boat to porpoise constanly. With 975hp a side and standard X we got 93mph full fuel, people, and adult beverages.
Almost forgot we ran Hydromotives and Bravo 1 4 Blades
P Offshore is offline
