How do I remove decals off a plexiglass windscreen? >
Old 04-07-2005 | 11:39 AM
Default How do I remove decals off a plexiglass windscreen?
I have a ugly beat fountain name in large decals across my windscreen. They are in bad shape and I want to remove them. Can you use a heat gun on a plexiglass windscreen or a solvent? Laquer thinner did nothing. The letters are about 18 inches high and it covers the whole windscreen.
Any idea's?
Kirk
Kirkc is offline
Old 04-07-2005 | 12:05 PM
EWPE's Avatar
Default Re: How do I remove decals off a plexiglass windscreen?
Just finished same thing on my Donzi . My 8 year old son spent 2 hours picking it off 1 piece at a time , he wanted to do it.. In the past I have used a hair dryer and an old credit card to take them off
EWPE is offline
Old 04-07-2005 | 12:44 PM
If you use a heat gun keep the distance and never stop moving. You might try a black tarp in the sun for a few minutes. You may need to refinish/polish the whole thing when you're done anyway. There are some good plastic polishers on the market.
cooltoys61 is offline
Old 04-07-2005 | 12:53 PM
I removed factory stickers from sheets that wouldn't peel off by soaking in WD40 or vegetable cooking oil.
Gary
Gary Anderson is offline
Old 04-07-2005 | 01:26 PM
Registered User
There's a product called "Goof-Off" that works well and shouldn't hurt the Plex. Lowes/Home Depot has it
Chris Sunkin is offline
Old 04-07-2005 | 01:33 PM
Registered User
There's also a product called Sticker-Off from Hardline products- available in motorcycle stores
Old 04-07-2005 | 01:38 PM
Harper220's Avatar
I have removed many decals and the heat gun will soften it right up and come right off. Just watch the distance of the gun, keep it moving and don't get it too close. I wouldn't bother with all the chemicals and solvents.
Harper220 is offline
Old 04-07-2005 | 01:45 PM
Use a pressure washer, it'll peel it right off.
bill1135 is offline
Old 04-07-2005 | 01:52 PM
Thanks to all of you. I appreciate all the great ideas.
Kirk
Kirkc is offline
Old 04-07-2005 | 08:23 PM
mcollinstn's Avatar
Heat gun.
Goo-gone.
mcollinstn is offline
