I need a Starter Fuse Assembly ??? >
Old 04-13-2005 | 12:17 AM
Strip Poker 388's Avatar
Rob
Default I need a Starter Fuse Assembly ???
Is this a special Mercury Marine part or can I buy it a Napa or something like that? I am trying to find it locally and quick.
Mercruiser Starter fuse 90 amp merc. # 88-79023A-91
http://www.go2marine.com/g2m/action/...egoryId/13621/
Strip Poker 388 is offline
Old 04-13-2005 | 12:31 AM
hillbilly24's Avatar
Default Re: I need a Starter Fuse Assembly ???
Napa should stock em ive never tried to buy one from them but they are used on alot of import cars just ask them for the electrical picture book and look under fuses.
hillbilly24 is offline
Old 04-13-2005 | 07:02 AM
Mbam's Avatar
Offshoreonly Advertiser
If you're stuck we keep them on the shelf, unfortunately Mercury is very proud of them. It would get expensive however with next day shipping.
http://www.mercruiserparts.com/partsByNumber.asp
Mbam is offline
Old 04-13-2005 | 12:57 PM
Rob
Napa doesnt have them . I looked thru there echlin book nothing even close . They called it a relay idiots
Any other sugestions??
Old 04-14-2005 | 08:35 AM
Rob Call me when you can
amarket1 is offline
Old 04-14-2005 | 09:10 AM
Scott's Avatar
Charter Member #30
I know it says fuse but is that actually a breaker? If it is a fuse how inconvenient is that
I have Steps & Bubbles!
Scott is offline
Old 04-14-2005 | 09:31 AM
no it actually is a fuse but they only blow if you have a major short to ground.
Old 04-15-2005 | 12:33 AM
Rob
I am told it just for the coast guard safety stuff.it must of shorted out hooking it up?
Old 04-15-2005 | 06:16 AM
Mbam's Avatar
Did you hook the battery up to the stud on the fuse or to the starter?
It goes on the starter, otherwise you are trying to feed the starter through the fuse, which will pop it instantly ----
Mbam is offline
Old 04-15-2005 | 08:27 AM
Rob
it was in the starter. we went to crank it on the dyno and it was blown.No biggie
