Extreme Trailer, disk brake question >
Old 04-14-2005 | 08:28 PM
Question Extreme Trailer, disk brake question
I have a 3 year old tandem axle trailer from Extreme (with leaf springs as opposed to torsion bars) and with four wheel disk brakes. I have noticed that there seems to be ongoing "clanking" noises when hitting any kind of bump or rough payment for quite some time so I took it to a local trailer repair place. They say that they have never seen that type of disk brake design before where the calipers seem to be held on with only one bolt. They normally see two bolts holding the calipers on. It looks like the calipers are loose and are clanging around when I hit bumps. One of the brake pads was even worn at an angle. The local guy talked to Extreme and was faxed a drawing but it doesn't look like there are any replaceable bushings or other parts except for the calipers. He thinks the only thing to do is replace the calipers but that it will happen again with this single bolt mounting design. Does anyone have any experience with this type of design?
Thank you, RR
Robbie Racer is offline
Old 04-15-2005 | 09:04 AM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Default Re: Extreme Trailer, disk brake question
Never ever heard of anything like this. Got any pics? Can a second mount be welded on?
Sydwayz is offline
Old 04-15-2005 | 09:07 AM
I will try to get some pictures in a few days.
Thank you, RR
TP121
5
06-06-2006 09:30 PM
dockrocker
18
06-27-2005 12:03 AM
Fuhgedaboudit
4
03-29-2004 06:34 PM
scarabrick
04-05-2003 11:00 AM
dyno
9
10-10-2002 03:28 PM
