Go Back  Offshoreonly.com > Owners Forum > Eliminator
Trying an IMCO 2" shorty on my Twinstep >
Old 01-05-2002 | 06:46 PM
Cattitude's Avatar
Cool Trying an IMCO 2" shorty on my Twinstep
I just bought a 6hr XZ from "Sterndrivespec" with an Imco 2" shorty. It may be too tall for the already high x on my twin step but now we'll know. Unfortunately my 25' Daytona is stored for the winter so I won't know til late march or so. worst case I'll need a 1" spacer. I know the 2" shorties pickup 5-6mph on the 1.75" lower x single step. I'll fill in the results when the time comes. I also bought BC's Merc labbed 28 so that should be good for a few also.
Cattitude is offline
Old 01-06-2002 | 10:06 AM
Post
Catitude,
Please post your results good or bad Ihave the same twin step hull and will very interested in your results.
Liquid Kroozir is offline
Old 01-06-2002 | 07:03 PM
aTX427's Avatar
Post
Bust it out for a test run!
aTX427 is offline
Old 01-06-2002 | 09:58 PM
RON
Post
Yea, the weather can't be that bad, down there in Arkansas!!
And if you don't like that 2" shorty, you can make me a smokin deal on it ,and i'll try it on my single step 25!
Old 01-07-2002 | 09:29 AM
Cattitude's Avatar
Post
You guys don't watch the weather channel, It's 30 degrees, I've got an inch of snow and I just got back from pulling wy wifes MR2 out of the ditch- Car & wife- I mean wife & car are both ok . I'm sure once all the parts actually get here it will be awfully tempting- of course there's that lack of insurance thing.
Old 01-07-2002 | 03:02 PM
Cattitude's Avatar
Thumbs up
Update- I called Imco to ask about hooking up the speedo to the shorty (Need to use Pitot on transom) and asked about the 2" shorty for my twinstep- they sent me to Jerry May at Eliminator. I've talked to Brent and Mike before but never Jerry. Jerry is the dial in guy. He set up the twin step that did 127 in the PB shootout and has had twin step 25's up to 138 mph. Jerry told me that the 2" would work fine in the twin step and that they had tested with even higher x's. He sid it would likely slip a little out of the hole but would be faster for sure. I asked if there were any negative effects that I would be compromising- he said that it would drift more in the high speed turns (2" less rudder in the water too) instead of carving but that you get used to it, also all else being equal I'd have to slow down a little more to execute the turns (that's ok with me). He did say I might have to bump to a higher prop size but to try what I had for now. I'm very encouraged by this news from a man with this experience and credibility.
Old 01-07-2002 | 06:00 PM
Post
I have that problem at speed with it wanting to move sideways. Can the skeg be welded on and made 2" longer?
cobra marty is offline
Old 01-07-2002 | 06:29 PM
Cattitude's Avatar
Post
CM- I had the same thought- I'm betting it can- it would be great to get the AMS spec of the alloy- I should be able to get that from IMCO. One of my buddies is an awesome tig welder- does aerospace stuff and go-cart frames- I stick to the mig gun myself.
Old 01-07-2002 | 10:57 PM
merlin540
Post
i had 2" shortened cases on my 27 daytona and i added 3" to the skeg. you have to weld it on with a high frq tig. any good fab or welding shop can do this and it will stay on. mine stayed on at 122 so i know it works.
Old 01-08-2002 | 11:51 AM
khadley's Avatar
Post
you should pick up speed i have done three older daytona's and they all picked up 8-10 mph the prop will blow a little as far as the speedo why not put a gps speedo in it they work so much better good luck and post the results i have two guys with 25's (twin step) daytona's wanting to do the same thing
khadley is offline
