New U-bolts Ready To Ship >
Old 04-18-2005 | 06:16 PM
WILDTHING TAZ's Avatar
B-MAX REPAIR
The New U-bolts Are Finished And Ready To Ship. There Made Of An 17-4 Ph. They Are thread Ground And Come With 2 Monel Nuts. Oem U-bolts Tested At 8300 Lbs Before Stretching Or Stripping Off The Nut. These U-bolts Went To 15,000 Lbs. The Install Will Be Torque At 55 Lbs. You Must Use A Good Lube On The Threads So You Don't Gull The Nut To The U-bolt When Tightening. This Will Solve The Problem That Heavy Or Bigger Hp Boats Are Having. So If You Send Me Your Gimbel Ring To Rebuild You Do Need These U-bolts!!! Cost Will Be $55.00 Each.
Ron Bender 216-390-1330 :d
WILDTHING TAZ is offline
Old 04-21-2005 | 09:49 PM
B-MAX REPAIR
Default Re: New U-bolts Ready To Ship
Photo Of U-bolt & Monel Nuts
Attached Thumbnails New U-bolts Ready To Ship-dsc01753.jpe
Old 04-21-2005 | 10:43 PM
hillbilly24's Avatar
Wow those threads are so fine I can't even see em
hillbilly24 is offline
SkiDoc
DCB
6
11-12-2007 12:44 PM
CPPerformance
New Products and Member Discounts
0
02-20-2007 01:03 PM
thisistank
03-26-2005 09:47 PM
