Recommended oils for 2003 Merc 300x ? >
Old 04-20-2005 | 12:27 PM
berns29scarab's Avatar
Default Recommended oils for 2003 Merc 300x ?
Going from I/O's to eggbeaters and just wanna get some thought on who's oil's you like, for both 2 stroke and gear case. Thanks
berns29scarab is offline
Old 04-20-2005 | 06:38 PM
Default Re: Recommended oils for 2003 Merc 300x ?
Buhler....anyone ?
Old 04-20-2005 | 06:47 PM
t500hps's Avatar
21 and 42 footers
all 3 of the people w/ eggbeater's aren't on tonight Talk to the bassboaters
t500hps is offline
Old 04-20-2005 | 07:01 PM
lmao...no problem
Old 04-20-2005 | 07:42 PM
stick with the Mercury Premium plus anything synthetic will be a waste of money on the 300X. If it were the 2.5 racing synthetic is advised. I still use the Merc. Hi-Perf gear lube. Too much contoversey over what would be better then the Merc. stuff.
Donzi Corleone is offline
Old 04-20-2005 | 07:54 PM
Crossing over to the "Darkside"
Check out Scream & Fly.com. Pennzoil synthetic is also popular. I run Merc oil at present, buy it at Sams Club by the case. Walmart supposedly has the best $ on Pennzoil. Merc oil in the drive.
Good luck with the new boat
Speed2lead, gonna make the OPBA Poker Run?
Johno is offline
Old 04-20-2005 | 07:57 PM
cuda's Avatar
Johno, while you're doling out advice, what speed is best to run when trolling for kingfish?
cuda is offline
Old 04-20-2005 | 08:23 PM
Cuda, it's nice to boat every weekend. Turn the key & go. Admit it, your # 1 boat has an eggbeater & a bimini.
Johno is offline
Old 04-20-2005 | 08:27 PM
Pantera1's Avatar
Merc shmerc ..walmart tech 2000 ..6$ a gallon
Pantera1 is offline
Old 04-20-2005 | 10:11 PM
dreamboater's Avatar
Klotz TCW3 full synthetic, and Mercury Hi Perf gear lube. I run this in a pair of 300 promaxs. Maybe over kill but safe for sure.
dreamboater is offline
