Toe IN or Toe OUT >
Toe IN or Toe OUT
Toe IN or Toe OUT
Old 04-22-2005 | 04:01 PM
Rookie's Avatar
Default Toe IN or Toe OUT
I am going to switch drives from turning out and try running them turning in. Do I need to setup the toe on the drive different. I don't know if it is in or out now, but I would like to set it up right now.
How much toe if props are turning in? (in"/out")
How much toe if props are turning out? (in"/out")
Rookie is offline
Old 04-22-2005 | 04:19 PM
Sean H's Avatar
A to Z
Default Re: Toe IN or Toe OUT
i think dead on parallel is what you are looking for.... but i am not a vee guy so maybe else will chime in here....
Sean H is offline
Old 04-22-2005 | 04:22 PM
mopower's Avatar
Toxic FORMULA
A friend of mine called Formula to check on this months back and they said "straight".
mopower is offline
Old 04-22-2005 | 04:43 PM
racer-x6's Avatar
Straight is where you want to be.
Measure the center line dim. of the gimble housing and adjust the tie bar so that the prop shaft canter line is the same.
racer-x6 is offline
Old 04-22-2005 | 06:08 PM
I always measure the center of the propshafts compared to the center of the nosecones
mmwalters is offline
Old 04-22-2005 | 07:27 PM
t500hps's Avatar
21 and 42 footers
The 31 Formula I just bought was set up to turn in. I grew up on bassboats and the ride was similar in that the azz end felt loose. Turned the props out and the ride was much more stable. Actually picked up 1 MPH, but that may be due to driver in-experience and a new to me boat.
t500hps is offline
Reckless32
Sunsation
16
07-06-2006 06:13 PM
rv
3
05-20-2006 08:30 PM
Monty
10
07-15-2004 01:15 AM
formulaF302
2
06-10-2003 10:55 PM
Raypanic
Powerquest
1
05-22-2002 08:36 PM
