Do prochargers make noise @ idle? >
Old 04-24-2005 | 10:32 AM
Default Do prochargers make noise @ idle?
I have just installed a used procharger M-1 on a 7.4 MPI and it makes noise @ idle. I have read threads stating that prochargers do make noise. The noise goes away off idle, I assume as pressure against the turbine blades becomes greater. The previous owner suggested the use of straight 40 wt oil. Any suggestions?
baronbob is offline
Old 04-24-2005 | 12:13 PM
articfriends's Avatar
Default Re: Do prochargers make noise @ idle?
Mine sorta has a ringing sound like gear noise,you would think the bearings or gears were going out of it but it's been doing it for 4 years since new,Smitty
articfriends is offline
Old 04-25-2005 | 05:52 AM
Mine did it, really worried me, but is the norm. Mine either got quieter, or I didn't notice it as much after several uses.
SkiDoc is offline
Old 04-25-2005 | 12:01 PM
Strip Poker 388's Avatar
Rob
Most that I have seen do.
Strip Poker 388 is offline
Old 04-25-2005 | 01:04 PM
tssteph's Avatar
My brand new ones do. At least with the hatch up I can hear it. I am told that you should only use procharger oil, looks thinner then 40 wt to me.
100 hours between changes. I would buy the right stuff.
tssteph is offline
captsmith302
Wanted
4
06-23-2008 09:07 PM
chkmt251
Fountain
38
02-26-2007 10:57 AM
LAKESIDE RESTORATIONS
New Products and Member Discounts
5
12-16-2005 08:11 PM
Wild
14
03-09-2005 05:31 AM
