STARTER MAKING "LOW CYLINDER" SOUND?
Just Had One Of My 575's Pulled At Innovation For What Sounded Like A Dead Cylinder While The Engine Was Turned Over. (not Running) Engine Had 230 Hours On It And What Seemed Like A For Sure Stuck/bent Valve Turned Up As Nothing When We Pulled The Heads. No Valve, Rocker, Pushrod, Camshaft, Gasket Or Any Obvious Cylinder Damage To Be Found. Yeah, I Know We Should Have Leaked It First But It Just Seemed So Obvious That We Didnt Bother. We Have Come To The Conclusion That It Could Be A Ring Gear Or Starter Problem. (worn In One Area To Cause A Change In Pitch While Turning) Can Anyone Back This Up?
Originally Posted by SCRAPMAN1
It Wasnt Easy To Tell. All We Heard Was A Change In Pitch.
Pumped up lifter or a sucked in valve? Hard to believe the ring gear is the problem but ya never know. Good luck,tell Rick I said hello.
K-WELLS
Cigarette
4
07-27-2007 09:39 PM
mikesufka
12-26-2002 11:23 AM
