575SCI blower oil change. >
Old 05-02-2005 | 03:37 PM
Blower Oil change maintenance:
This last weekend I decided to finally attempt the blower oil change. I had previously been discouraged by the idea of complete blower removal just to change oil. I found this method very easy and didn’t involve removing the blower and turning it upside down. 30 minutes to change the oil and an hour if you modify it with a drain plug. I spent another hour at the hardware store getting a plug, 5/16-drill bit and a 1/8” pipe plug tap. From my understanding of BBQ70’s posted info, I have the late style blower with a sealed rear bearing and a B&M style front cover so I don’t have any rear oil to change.
1.Remove the blower belt by releasing the tensioner.
2. Stuff big towel under blower snout and front cover.
3. Loosen all of the front cover bolts without removing completely.
4. Begin to loosen Allen fill plug on top. Front cover will pop loose.
5. Blower oil will drain into towel.
You could at this point tighten the bolts and refill.
I decided to remove the cover completely and drill a hole and thread for a 1/8” pipe plug in the front cover just to the left of center near the bottom. Now I can change the oil
Without loosening the cover. If you remove the cover completely be careful with the gasket. I was able to reuse the gasket but otherwise you might need a new gasket. I took some pictures but am not sure how to post them.
zahndok is offline
Old 05-02-2005 | 10:55 PM
cdscarab's Avatar
Default Re: 575SCI blower oil change.
I was going to do something like that when I realized that that there might be an easier way. I took my vacuum oil changer (topsider), removed the plug in the top of the front cover and vacuumed out the oil. Took about 5 min. to get it all out and about another 20 min. to clean up the mess after over filling with new oil. Definitely the way I'll do it from now on.
cdscarab is offline
Old 05-26-2005 | 12:33 PM
hello,
witch oil did you use in the blower?
Thanks Sake
bubba is offline
Old 05-26-2005 | 01:48 PM
Steve Zuckerman's Avatar
Hi Guys:
Mercury says to use standard HP Merc gear oil in the blower, and that would probably be fine. But since it's an expensive toy, I've been using Royal Purple 75W-90 Max-Gear in mine with good results.
Here's a little more trivia, the 1st time I changed the oil in mine, it appeared to have RP in it from the factory........same color and consistency.
Regards,
Steve
Steve Zuckerman is offline
Old 05-26-2005 | 02:03 PM
Steve Thanks allot this helps me very very much
thanks again Sake Bijlsma
bubba is offline
Old 05-26-2005 | 05:02 PM
Anytime, Sake.
You're welcome.
Steve
Old 05-26-2005 | 11:34 PM
Originally Posted by Troutly
Me wonders why they did not think of making an easy way of changing the blower oil straight from the factory? Installation of a simple drain plug from the get-go would seem to make sense.
Probably want you to take it to an authorized Mercury Racing dealer so you can pay $200 to have it done
Troutly,
Funny you mentioned that. That's exactly what is says to do in the 575 manual ...........
Steve
Old 05-27-2005 | 08:12 AM
BillR's Avatar
OSO Moderator
How about the rear section of the blower? Did you change the oil there too? If so, how did you do it?
On the front part, did it make a big mess, or did the towel absorb all of it?
Thanks for the instructions. Wondered how to do it. The older style blowers are easier, just suck the oil out w/ a pump and refill.
BillR
'00 Scarab Sport 302 CC
'02 Cigarette Top Gun TS
'02 PQ 340
'00 PQ 280
'98 Scarab 22
'97 Baja Outlaw 20
'72 Checkmate
'65 Glastron
BillR is offline
Old 05-27-2005 | 10:08 AM
Canada Jeff's Avatar
I have heard of the oil posibly having some feul contamination. I take it you didn't smell fuel or see any floating?
We'll be changing ours by means of a sucking tool soon. We have to change the thermostats too.
Canada Jeff is offline
Old 05-30-2005 | 08:15 PM
I just checked my oil level this weekend, and since being freshened by the Blower Shop and relubed by me 25ish hours ago, the oil level is perfect but is starting to get a little bit of the burned smell like an overdue gearcase change.
I couldn't detect the smell of fuel in the oil fortunately.
I'm spinning my blower pretty fast (3" pulley/4" stock), so that is probably why the accelerated deterioration is occurring.
Will be changed ASAP.....a lot cheaper than a new blower!
Steve
