Does anyone use a fuel flow meter? >
Old 05-02-2005 | 08:44 PM
Default Does anyone use a fuel flow meter?
With gas prices it would be nice to know what rpm and trim settings would give the best GPH. Are they worth the money?
Shah Mat is offline
Old 05-02-2005 | 09:10 PM
Stormrider's Avatar
JC Performance Engines
Default Re: Does anyone use a fuel flow meter?
I bought one, but its only good for 300hp.
Now that I'm running 560hp, I wouldn't want it to restrict fuel flow, so its coming out. My dyno sheet gives me an idea of what I'll be burning, but it only shows from 4000rpm and up.
But I agree, its nice not only to know how much your burning, but to maximize cruising range.
Stormrider is offline
Old 05-02-2005 | 09:37 PM
hey Shah Mat,
I have one on my 42 Sonic and it is well worth the money. I use for getting the total fuel consumption on a trip then on the way back put only what I used going out. Once you get the averages right you can run less gas in the boat thereby running the boat lighter on short trips rather than topping off everytime out.....I have 502's in my rig.....
stretchnout is offline
Old 05-03-2005 | 05:24 AM
WildWarrior's Avatar
They work well on my Gun, it's amazing how a few hundred rpms can mean the difference between 20 GPH per side and 30GPH when cruising.
I use mine to determine cruise speed alot ,you don't even want to look at it when your into boost!
WildWarrior is offline
Old 05-03-2005 | 06:04 AM
Poorsche's Avatar
I'm installing a B&G Network Engine device. It works using data from the ECU and displays fuel consumption, coolant temp, voltage and more. Guage connects to ecu with single shielded wire and cost less than Floscan.
http://www.bandg.co.uk/pdfs/FAQs/faq032.pdf
Poorsche is offline
Old 05-03-2005 | 06:52 AM
excursion's Avatar
I have the alternate one, out of gas take money out of wallet and buy more when wallet is empty have full gas tank.
excursion is offline
Old 05-03-2005 | 08:08 AM
we use the faria digital flowmeter in many boats they work awesome and are reasonable cost they worked on a pair of 750,s no problem but i,m sure they were at there max flow.....it is a drop in 2 inch gauge
boostbros is offline
Old 05-03-2005 | 10:29 AM
GLH's Avatar
GLH
Flowmeter? Feeling a tad masochistic this morning.
GLH is offline
Old 05-03-2005 | 10:48 AM
DollaBill's Avatar
OSO OG
There are some good ones out there that won't cause flow problems. I know someone with 575's who has meters and has never had any issues.
DollaBill is offline
Old 05-03-2005 | 11:37 AM
45sonic's Avatar
We don't want to know.....it would make us sick.
45sonic is offline
