Cleaning neglected aluminum wheels?? >
Old 05-03-2005 | 11:25 AM
dkwestern's Avatar
Default Cleaning neglected aluminum wheels??
What product is good to clean neglected aluminum wheels. They have some corrosion and minor pitting. Basically left unattended for a couple years outside.
I have tried generic cleaners, like mothers, and Flitz.
Is there an acid that i could use?? I have heard people talk about dipping them, but what do they dip them in? Any help is appreciated.
dkwestern is offline
Old 05-03-2005 | 11:32 AM
CFD5's Avatar
Default Re: Cleaning neglected aluminum wheels??
I have a set of Boyd Coddington wheels on my van that need some cleaning. I e-mailed Coddingtons shop asking what cleaner they use without damaging the wheel. They sent me a link for a company. Said they only use this stuff. Have not tried it yet myself but here you go.
http://www.heavymetalpolish.com/
CFD5 is offline
Old 05-03-2005 | 11:58 AM
Smile Re: Cleaning neglected aluminum wheels??
I use Muriatic acid, Cut about 50% w/ water brush it some or just let it sit a couple of minutes, then hose off b4 it dries.If the wheels are real bad use a slightly stronger mix or simply re- apply the previously mentioned mix.Enjoy a beer, a woman,or fix something else with the time you saved.
nightmoves is offline
Old 05-03-2005 | 01:29 PM
What if your SO cleans the wheels?
BadDog is offline
Old 05-03-2005 | 02:52 PM
dkwestern's Avatar
This sounds like the ticket, where do I get it?? Auto parts store?? Thanks in advance
Old 05-03-2005 | 03:36 PM
Any hardware will have the Muriatic Acid. Be careful not to get it on concrete, asphalt or any unpainted areas of the trailer. That stuff is pretty caustic.
BadDog is offline
Old 05-04-2005 | 01:11 AM
Strip Poker 388's Avatar
Rob
It will also etch[screw up] chrome Lug nuts .I did it once on a car trailer. If ya breath it Its like the strongest bong hit ya ever had
Strip Poker 388 is offline
Old 05-04-2005 | 08:04 AM
This stuff works great on machined aluminum wheels. It's a strong etching acid mixture that requires a polish after use.
http://www.eagleone.com/_products/0,1010626.asp
NightHawk is offline
Old 05-04-2005 | 08:09 AM
Rookie's Avatar
If the clear coat is already gone, then I would use semi-chrome, a 25,000 rpm die grinder and a 2" buffing ball and turn them into mirrors.
Rookie is offline
Irishtornado
10
09-02-2008 08:16 AM
Little Tommy
20
08-13-2008 05:51 AM
Craney
6
01-30-2005 08:45 PM
mama tryed
12-13-2003 06:10 AM
mxz800
05-05-2002 11:01 PM
