Truck question >
Truck question
Truck question
Old 05-05-2005 | 12:08 PM
mopower's Avatar
Toxic FORMULA
Default Truck question
99 F350 4x4. The 4x switch on the dash does nothing...as in no 4 wheel drive. Any common problem to check first???
BTW , no 4 wheel high or low
mopower is offline
Old 05-05-2005 | 03:36 PM
mopower's Avatar
Toxic FORMULA
Default Re: Truck question
Wow , a real bunch of knowledge here
mopower is offline
Old 05-05-2005 | 03:41 PM
articfriends's Avatar
Find fuse and check first,does switch normally light up?Could be encoder/servo motor on t-case but sounds like power supply to me,Smitty
articfriends is offline
Old 05-05-2005 | 04:46 PM
mopower's Avatar
Toxic FORMULA
Check voltage on wire to servo with key on and nothing , checked fuse , OK.
Damned electric crap , there was nothig wrong with a manual t-case
OOPS time to check again.....I measured across the two wires not wire to ground
mopower is offline
Old 05-05-2005 | 05:11 PM
mopower's Avatar
Toxic FORMULA
Nuttin there either
mopower is offline
Old 05-05-2005 | 05:41 PM
mopower's Avatar
Toxic FORMULA
Originally Posted by sutphen30
are your hubs on the wheel in the "free" position,put it to lock.
That's a non issue since the t-case isn't shifting and the 4x light on the dash isn't coming on.
If I lock the hubs everything turns but it's still not in FWD.
I found this out Monday when I tried to pull the boat 150' across my back yard on wet grass
mopower is offline
Old 05-05-2005 | 06:02 PM
Outdrive1's Avatar
Masher touches my
Mine did the same the same thing last year. The plug on the drivers side of the transfer case was loose. It's right behind the front drive shaft. You should be able to turn the switch on and reach up in there and wiggle it to see if it works, when it does it will click loud enough to know that you did something. Its actually the position sensor. I unbolted it (position sensor), cleaned the connection and put it back to gether and it works fine now. It comes out real easy, this is an easy job. You'll have to drop the skid plate but it comes out with 4 or six bolts. The hardest part is bolting the skid plate back up by yourself. I tried every relay, fuse, ran power to the switch from the fuse block, nothing worked. I had replaced the tranny last year and I'll bet the Ford dealer never plugged it back in all the way. Its real hard to push in until you unbolt the sensor because of the wierd angle behind the drive shaft area. Give it a try and let me know if it did the job.
Outdrive1 is offline
Old 05-05-2005 | 06:08 PM
mopower's Avatar
Toxic FORMULA
There are two plugs. One on an object that resembles a power window motor , That's near the bottoom of the case. Theres another plug at the top of the case. removed and replaced both. Both appeared tight and clean.
mopower is offline
Old 05-05-2005 | 07:09 PM
Outdrive1's Avatar
Masher touches my
The one that looks like its on the "window" motor is the position sensor, thats where my bad connection was. I looked at everything else in mine and stumbled upon that. I would unbolt the position sensor and adjust it by hand and see if you can make it work. It's easy enough to take off and at least you'll know whether or not it's bad. Other than that I couldn't tell you where to begin. Like I said I couldn't find any other way of making mine engage until I messed with that. I also thought I could push it in by hand but I was getting it tight enough until I took it off and made the clip engage. It goes in alot deeper than you think. Thats why it would work when I was down there pushing on it but it wouldn't work from the cab by itself. It could be something else all together but this isn't that hard to check. I dont think the hubs have anything to do with the transfer case engaging, so more than likely its somewhere inbetween that sensor and your switch. You can do search engine to find schematics on the relays and fuses so you know exactly wich ones to check under your hood. I had them written down but I have no idea where I put the paper. I believe there are a couple of fuses in the fuse box too in the dash but I'm sure you already checked them.
Old 05-05-2005 | 07:10 PM
Outdrive1's Avatar
Masher touches my
I'm trying to tell you not to trust just pushing it in by hand, that connection was difficult to connect properly on mine. Maybe yours is a little easier but I would have missed it if I hadn't been under there, with the switch in 4x4 pushing on it at the same time.
