Push rod length checkers?? >
Old 05-07-2005 | 07:39 AM
Default Push rod length checkers??
Bought new heads for my stock 454s. Head mfgr says I need to check for proper rod length. So, I bought some appropriately sized "push rod length checker" gizmos. One size for intake and another for exhaust.
Question is, I don't know how to use these things. Do I go by feel as when setting up the valve train? Or, should I be measuring lifts?
Thanks for any help.
ThirdBird is offline
Old 05-07-2005 | 08:02 AM
Vinny P's Avatar
I hate the winter!!
Default Re: Push rod length checkers??
If you have never done this check before, the best place for information on how to do it is on CompCams website.
http://www.compcams.com/Technical/Products/Pushrods/
Vinny P is offline
Old 05-07-2005 | 10:29 AM
Thanks for that link Checkmate. Read through it, goog thing I did. However, CompCams was referring to a roller set up, mine is flat tappet hydraulic. I'll have to do some more investigating.
Old 05-07-2005 | 10:44 AM
PatriYacht's Avatar
It basicly works the same way. You want to end up with a small contact pattern centered on the valve tip.
PatriYacht is offline
Old 05-07-2005 | 10:52 AM
So, basically as perpendicular as possible (rocker to valve)?
Old 05-07-2005 | 11:23 AM
Vinny P's Avatar
I hate the winter!!
As was said, it doesn't matter what type of rocker arm you are using. The contact pattern should be the same. Just follow the instructions on that link.
Vinny P is offline
69-CHVL
3
08-13-2007 12:43 PM
1BIGJIM
3
03-26-2007 09:32 PM
Nordicflame
16
01-09-2006 09:52 PM
batty
5
06-08-2005 03:51 PM
HyperBaja
35
12-26-2002 02:57 AM
