Spark Plugs
Old 05-11-2005 | 01:58 PM
Default Spark Plugs
What spark plugs should I use in my 87 454 mag? I was thinking about going to the AC Rapid Fire's.
Dan
danielthelen is offline
Old 05-11-2005 | 03:28 PM
Hydrocruiser's Avatar
Arrow Re: Spark Plugs
Dan
The ECM in my boat didn't like split-fires for some reason ..just an fyi
Personally I like NGK's best....they just seem to allow the engines to idle better.
Hydrocruiser is offline
Old 05-11-2005 | 03:40 PM
Default Re: Spark Plugs
AC MR43TS
Its the extended tip version of the stock plug.
Griff is offline
Old 05-11-2005 | 04:24 PM
NGK BR6FS
will work.
JaayTeee is offline
Old 05-11-2005 | 04:57 PM
formula31's Avatar
Originally Posted by Griff
AC MR43TS
Which isnt available anymore. The Rapidfire#1's are the same. Im trying those this year instead of the MR43's
formula31 is offline
Old 05-12-2005 | 01:21 AM
I did not know the MR43TS's weren't available. I did know that the Rapid Fires were a cross ref for them.
Rapid Fires are good, but pricey if you don't need them.
You could just run the automotive version R43TS. If you change them every year, they will be fine. they aren't SS and will rust slightly.
Griff is offline
Old 05-12-2005 | 06:45 AM
formula31's Avatar
Yea, they are pricy. They have a CR43TS now that may be the same thing as the MR. I havent looked at one yet.
Old 05-13-2005 | 02:19 PM
I'll give them a try.
Old 05-13-2005 | 05:25 PM
Scott's Avatar
Charter Member #30
MR43T MR43TS
I have to wonder if it is a generic picture or if they changed them from the stainless version?
I have Steps & Bubbles!
Scott is offline
nordic95
10
09-13-2007 01:55 PM
fountainguy214
3
07-01-2007 10:40 PM
Liberator21
6
01-10-2004 12:09 PM
Rick G
5
09-05-2003 07:11 PM
sixpak
5
04-21-2003 05:35 PM
