Help with Trim Indicator bracket >
Old 05-16-2005 | 07:31 AM
Scott's Avatar
Charter Member #30
Default Help with Trim Indicator bracket
I need to find the piece that has the 2 holes in it. Livorsi sells the kit brand new for $193.00 it is nothing more than a small stainless bracket. Mine broke yesterday while I was pulling the drives off. Better now than in the water but it still ticks me off there is no reason for this part to fail.
I have Steps & Bubbles!
Scott is offline
Old 05-16-2005 | 07:34 AM
Scott's Avatar
Charter Member #30
Default Re: Help with Trim Indicator bracket
I ended up welding the bracket but I see the other one is starting to crack.
Who sells the regular style that attaches to the trim ram?
I had this General discussion area with no help. Imagine that a actual boating question
Scott is offline
Old 05-16-2005 | 06:03 PM
Scott's Avatar
Charter Member #30
ttt
Scott is offline
Old 05-16-2005 | 06:40 PM
formula31's Avatar
Scott, If you can give me some dimensions, I can make whatever you want up to 10 gauge if neccessary.
formula31 is offline
Old 05-16-2005 | 10:49 PM
Scott's Avatar
Charter Member #30
I am looking for the typical trim sensors that most boats have attached to the rams.
I can't believe no one can give me some info
Did a web search and came up with zip I guess I need to start looking through catalogs from Eddie Marine or whoever that sells these???
Scott is offline
Old 05-17-2005 | 12:59 AM
If you mean this one, its a merc item.
http://www.mercruiserparts.com/Show_...%28846063A1%29
Griff is offline
Old 05-17-2005 | 05:58 AM
martiniboat's Avatar
From: Brussels, Ont. CAN. Landlocked between Lake Huron, Ontario and Erie
Scott, if you get stuck give me a shout, stainless is my 'game'.
You need something built heavier than stock so the problem doesn't repeat itself...
I'd be happy to help, Brian
martiniboat is offline
Old 05-17-2005 | 07:51 AM
Scott's Avatar
Charter Member #30
Griff I think thats what I need thanks for the link.
Martini,
This is a horrible design and can't believe others are not having failures. The piece is designed to fail.
The trim cable that comes out of the boat is held by this bracket that is attached to the move-able part of the gimbal assembly so every time you steer the boat the bracket flexes.
What may work is a heavy duty bracket that is hinged so that it may move with the drive and maintain the cable position.
One other thing the way this is set up, for me to change over to the "normal" style I do not have enough cable coming out of the boat so I either have to run new cables all the way to the dash or hope they have an extra loop of cable hidden somewhere.
Can you hear my frustration
Scott is offline
TRYME
Wanted
0
02-27-2008 11:48 AM
Scott
05-15-2005 09:11 PM
TTREMELLEN
General Racing Discussion
7
02-24-2005 07:22 PM
Krumbsnatcher
6
07-01-2003 09:12 AM
