What carb came on 420 HP Engine? >
Old 05-16-2005 | 08:58 PM
gripit's Avatar
Default What carb came on 420 HP Engine?
I'm having a hard time identifing my carb. Does anybody know what carb came one th 420 hp from Mercruiser. I know its a holly 4 barrel with no choke?
gripit is offline
Old 05-16-2005 | 09:58 PM
Default Re: What carb came on 420 HP Engine?
800cfm Holley with mech secondaries. I'm about 90% sure on this.
Griff is offline
Old 05-16-2005 | 10:18 PM
gripit's Avatar
This carb has no choke bowl so I cant find the serial numbers. The only number i found was 8543 with a 4 under it on the top right hand side of the float housing?? Mercruiser said it should be a 4781 but when I go to holly the 4781 looks different. ??
gripit is offline
Old 05-17-2005 | 06:17 AM
PatriYacht's Avatar
My 420's had 800's with electric chokes. Maybe your carbs aren't stock.
PatriYacht is offline
Old 05-17-2005 | 02:06 PM
thespy's Avatar
hollley 9022, electronic choke.
contact chief engines. ft laud, fl.
thespy is offline
Old 05-17-2005 | 02:25 PM
mtgbiker's Avatar
800 cfm Holley/ mechanical secondaries & electric choke.
mtgbiker is offline
Old 05-17-2005 | 04:45 PM
9022 is correct.
Here is the basics on the set-up from Holley. I don't know
if Mercury rejeted these or not:
800 CFM 4150 Marine
Front jets: 72
Rear Jets: 87
6.5 powervalve in primary
Compare to what you have now in the carb. The guys are
right, you may not have the factory carb.
OR
OLDRAT is offline
thumper038
Swap Shop
6
10-30-2008 04:34 PM
357sr1man
01-08-2006 06:43 PM
saulesses
4
10-17-2005 09:26 PM
gripit
18
11-27-2004 03:05 PM
Philip47
1
05-16-2002 08:09 AM
