Bravo gimbal bearing and MPH loss >
Old 05-18-2005 | 12:01 AM
Default Bravo gimbal bearing and MPH loss
I have a 2004 baja 29 outlaw with twin 496mags with 60hrs on them. When i took it out after winter lay up it made a noise thru the hull while running found out that the gimbals were bad. Even out of warrenty Merc repaird them. Since repaired I have a vibration when coming off plane and have lost a good 6mph off the top end. Any Ideas on the problem here....thanks
thosetwins is offline
Old 05-18-2005 | 12:38 AM
Waterfoul's Avatar
Gone Fishin'
Default Re: Bravo gimbal bearing and MPH loss
check your alignment. Have a GOOD mechanic check them... someone you trust... probably not the same shop that did the warrantee work from the sounds of it...
Or, take it back to the shop that did the warrantee work and complain...
Waterfoul is offline
Old 05-18-2005 | 06:04 AM
Pwrbt33's Avatar
Talking Re: Bravo gimbal bearing and MPH loss
Do you keep your boat on a lift or on a trailer? Have seen guys that keep them on a lift and have thrown a blade off and havent looked behind the boat to see it. If its on a trailer take a look all around, make sure that the prop thats on the boat is yours and have them check the alignment again. Should be close though, the drives on.
John
Pwrbt33 is offline
Old 05-18-2005 | 10:27 AM
The first gimble was replaced. Took to the lake and found that the second was bad. Brought back to dealer and had second replaced. While it was they did a drive alingment on orders from Mecruser. My good friend works at the plant and he writes warrenty service work for the production motors in Stillwater Ok. He is personally involved and it will get resolved but the servicing dealer can be a little difficult. These gimbles only have about an hour time on them do they need breaking in??
Old 05-18-2005 | 10:56 AM
Wobble's Avatar
SORE MEMBER
Have them check the props for "true" easy to bend a blade if they don't remove them prior to outdrive removal. Also it would be a good idea to check alignment of drives relative to each other and that they are trimming up the same.
Wobble is offline
Old 05-18-2005 | 11:23 AM
HiPerf2000's Avatar
I wonder if they remembered to grease them. A dry bearing may not spin as fast, but you would think that a BBC would make it spin no matter what.
Where was the boat stored all winter? Trailer? could the trailer not be set up right and have developed a hook in the hull ?
HiPerf2000 is offline
Old 05-18-2005 | 05:40 PM
Concerning the speed loss,
did you lose RPM's too ?
To lose that much speed, you
should have seen a loss of RPM's.
also.
This could just be an issue with the
speedo, or pick up.
( assuming it's not a gps speedo)
I had a vibration in mine at a certain
rpm, ended up being the props,
sent them to darin @ houston prop,
problem gone.
JaayTeee is offline
tpenfield
1
07-05-2005 07:27 PM
CN24
4
01-15-2005 07:25 PM
baronbob
2
08-26-2004 09:59 AM
Bankshot242LS
6
05-09-2004 04:18 PM
Bankshot242LS
04-23-2004 01:50 PM
