Bravo upper gear failure? >
Old 05-18-2005 | 10:01 PM
Question Bravo upper gear failure?
What is the cause of a bravo upper gear failureon low hour drives? How does one avoid bravo failure?
HOTTZU98 is offline
Old 05-18-2005 | 10:32 PM
Outdrive1's Avatar
Masher touches my
Default Re: Bravo upper gear failure?
Easy out of the hole if you have big power, watch your throttle if you catch air, the re-entries are very hard on the drive. Depending on your horsepower, no matter how careful you are eventually it'll die. If you have a small block, or big block that's non mag or non ho it may last forever for you. 500 hp or better, it's just a matter when not if.
Outdrive1 is offline
Old 05-19-2005 | 07:23 AM
rbtnt's Avatar
A year or two ago, Mercury had a bad run of upper XR gears that would fail at 25 - 50 hours. There were a couple of threads on it. Other than that, just what was said. I run billet top caps with integrated water cooling and they add strength on the left hand turning drives.
rbtnt is offline
thunderusone
Swap Shop
9
03-24-2009 01:14 PM
carter38
Wanted
1
07-30-2008 09:14 PM
bouncedcheque
Wanted
0
02-17-2008 12:55 PM
40hustler
Drives and Lower Units
5
05-29-2007 11:55 PM
cbgenrl
3
08-09-2006 10:16 AM
