Tech Tip - PUSHROD LENGTH AND ROCKER ARM GEOMETRY >
Old 05-19-2005 | 02:37 PM
KEPP's Avatar
Only the Best Will Do!
Default Tech Tip - PUSHROD LENGTH AND ROCKER ARM GEOMETRY
A large number of variables are involved in determining the correct length pushrod for your application. Any or all of the following affect pushrod length:
 Block Deck Height
 Head Deck Height
 Head Stud Boss Height
 Rocker Arm Brand/Design
 Cam Base Circle Size
 Lifter Design/Brand/Pushrod Seat Height
 Valve Stem Length
Do not assume anything in determining the right pushrod for your new engine. A pushrod that fits one engine may not necessarily work in another. Any number of items can be different on your engine, requiring you to use a different pushrod length. Following the steps below will streamline the pushrod selection process, ensuring that you get the right parts the first time.
Download the attached PDF file to read or print the rest of this article.
File Type: pdf
KEPP is offline
Ken N
2
10-04-2008 05:40 PM
estonian
1
09-03-2008 08:29 AM
fastlane40
7
02-15-2008 06:34 PM
Ken N
15
12-16-2007 11:20 AM
TROUBLE MAKER
0
09-01-2006 12:23 PM
