Tech Tip - DEGREEING THE CAMSHAFT >
Old 05-19-2005 | 02:39 PM
KEPP's Avatar
Only the Best Will Do!
Default Tech Tip - DEGREEING THE CAMSHAFT
What does “Degreeing the Camshaft” mean, and why is it necessary?
The term “Degreeing In Your Camshaft" means you are making sure the camshaft's position in the engine coincides with that of the crankshaft, so that their rotation is synchronized. This is the only way you will know if the rise and fall of the pistons properly matches the opening and closing of the valves, so the engine will run properly. A few degrees of misalignment can affect the engine's operation dramatically. If the circumstances were perfect, one would only need to line up the marks on the timing chain sprockets and the cam would be degreed. In reality, you are dealing with a group of components (the camshaft, crankshaft, timing chain, and sprockets), all with their own standards and tolerances. If these tolerances stack up against you, it could throw you out of alignment. Without degreeing the cam, you can never be sure that the parts are in correct position. If you have the tools and expertise, we always recommend that the camshaft's position in the engine be degreed in.
Download the attached PDF file to read or print the complete article.
File Type: pdf
KEPP is offline
Strip Poker 388
6
02-08-2006 12:41 PM
KEPP
5
05-20-2005 12:35 PM
KEPP
1
05-19-2005 09:21 PM
KEPP
0
05-19-2005 02:37 PM
KEPP
0
05-19-2005 02:34 PM
