How much fasted should 75hp make it go? >
Old 05-19-2005 | 04:01 PM
Ron P's Avatar
Enjoy the show
Default How much fasted should 75hp make it go?
Here's a question for ya.
If a certain single engine boat will run 80 with a Merc 525, how much faster should it go with a Merc 600?
What's the math on this one say?
Ron P is offline
Old 05-19-2005 | 04:27 PM
Smile Re: How much fasted should 75hp make it go?
About 1 MPH per $1,000
burtandnancy is offline
Old 05-19-2005 | 04:28 PM
Tantrum's Avatar
Default Re: How much fasted should 75hp make it go?
Ron
You know better than that, lots of variables.
If we are just guessing for fun I would say 84-86. 80mph is pretty fast already and its going to take some pretty big jumps in HP to push the hull faster.
Tantrum is offline
Old 05-19-2005 | 06:01 PM
onesickpantera's Avatar
Yep, I agree, lots of variables. But for fun I say you'd pick up about 4-5 mph
onesickpantera is offline
Old 05-19-2005 | 06:04 PM
1 mph per 20hp, or 1 mph for every 200lbs
yahoo is offline
Old 05-19-2005 | 07:08 PM
Jassman's Avatar
From what Ive been hearing the 525's are really pushing approx. 520-535hp. The 600's on a few 39 Nortechs and OL vs the 525's are seeing approx 2, maybe 3 mph. My guess in a single application would be 3mph, given all the variable were the same. Jeff
Jassman is offline
Old 05-19-2005 | 07:55 PM
Ron P's Avatar
Enjoy the show
Good answers. I was guessing at 3mph as well.
That's an expensive three miles per hour.
Ron P is offline
Old 05-19-2005 | 08:02 PM
It can be. I'm guessing this boat is in the 28' range? I would guess that you'd pick up a bit more than 3mph with a TRUE 75pshp increase. Unfortunately there is no general rule or formula. WAY too many variables.
Old 05-19-2005 | 08:31 PM
JCPERF's Avatar
Well a 525 makes 560 and a 600 makes 600 so you will pickup about 2 MPH
JCPERF is offline
Old 05-19-2005 | 08:48 PM
FX10's Avatar
Ron,
We tried this link to a speed calculator.
We took the variables from 3 of our 30 foot Y2K Superboats with 3 different motors. The calculations worked for all of them.
First motor was a 496 mag, 375 HP. between 68-70 on GPS
Next was a 496 HO. We know Keiths boat Once Bitten does 74.2 MPH on GPS.
And Fast Eddie with a 525, best day, 83 mph, gps.
In the calculator I needed to figure out the constant, so I put in the hull weight, 4500 lbs, hp @ 420, and known speed of 74. It gave me a constant of 242.
I then ran the program with the different hp motors. Here is what it calculated.
496mag- 70 mph (right on the money)
496 HO - 74mph (right on the money)
525 - 83mph ( Fast Edddys best )
600 - 88mph from the calculation on the link
I guess we'll all get to see what it does one of these days
Rick
FX10 is offline
