Tech Tip - ADJUSTING THE VALVE TRAIN >
Old 05-19-2005 | 07:29 PM
KEPP's Avatar
Only the Best Will Do!
Default Tech Tip - ADJUSTING THE VALVE TRAIN
Hydraulic Lifters
Hydraulic Lifters have been the choice of the marine industry for many years for several good reasons. When compared to a mechanical lifter, the hydraulics are:
 Quieter
 Low Maintenance
 Able to adjust for thermal expansion of the engine
 Equipped with a built-in shock absorber that eases stress on the valve train
 “Bleed rate” can be designed to accommodate different RPM ranges
Today’s modern engines all use either the standard design hydraulic lifter or the new low friction, high performance hydraulic roller design. Hydraulic lifters are the best for high performance and mild racing applications where low maintenance is a primary concern.
Download the attached PDF file to read or print the rest of this article.
File Type: pdf
KEPP is offline
Old 05-19-2005 | 09:21 PM
Default Re: Tech Tip - ADJUSTING THE VALVE TRAIN
Great article. Phewf i did it right!
revomaniac is offline
KEPP
5
05-20-2005 12:35 PM
ratman
03-28-2005 09:24 AM
KNOT-RIGHT
9
01-06-2004 01:01 PM
Pat McPherson
30
09-10-2003 07:01 PM
