5 stage dry sump oil system
Opinions will be appreciated.The application is 612 cu.in.,supercharged with a 6,000 rpm rev limiter.The pump is capable of producing 15 inches of vacumn.The concern is;should we use breathers or seal it up?If it is sealed and a piston burns,where will the fuel go?The boost will range from 5 to 8 pounds,subject to the quality of fuel.The oil tank is 4 gallons with a breather.Thanks for any comments.
Thanks JCPERF,These are new engines we are building.Piston oilers are being used.In fact,that is another issue:should the orifice size be .028 or .040? The wrist pins are DLC coated and the piston domes and skirts are coated.Also,the valve covers have spring oilers and we have sprayers for the solid roller lifters.However,if we use the lifter sprayers a screen will be fitted over the sprayer bar.Unless we were to not use a screen the closed scavange would over come screen restriction.Also,we have jessel belt drives.
Jc The Keyboard Just Froze Up ~bear With Me We Are Not Seperately Scavenging The Lifter Valley And Honestly Do Not Know How The Comment Has Been Heard ~use Bigger Nozzle Openings In Dry Sump And Smaller In Wet Sump~mike At Blp May Have A Breather That Sees Pressure Change And Opens When A Piston Would Burn~we Also Have Lifter Bore Bushings
The point is well taken~there is only so much volume available before it effects something else~probably leave the valley sprayers out~still concerned about creating a bomb if a piston burns when the sump is sealed except for the tank breathers~
Johnny,it is my understanding that dry sump vs.wet sump is a big part of the answer to your question.The wet sump has more oil coming off from the crank and therefore, gets that oiling benefit.The dry sump pump may be capable of more volume of cleaner oil.The spring oilers and .040 sprayers should work together in a dry sump system.
