2003 merc 300x's w/sport lowers. >
Old 05-22-2005 | 07:54 AM
berns29scarab's Avatar
Default 2003 merc 300x's w/sport lowers.
While taking props off last night i noticed a little play front to back on the prop shaft. Is this normal? Should there be any ? If not how do we rectify it? Sorry to sound like an idiot but havent owned an outboard since the mid 80's
berns29scarab is offline
Old 05-22-2005 | 12:08 PM
Default Re: 2003 merc 300x's w/sport lowers.
The service manual says end play on the prop shaft should be .045'' but when I bought a new in the box sportmaster from merc the end play was more like .080''. Both of my lowers are about the same with no ill effect. The end play is set by the reverse gear thruster washer but merc only offers one washer. I think you are OK so don't worry about it
mmwalters is offline
Old 05-22-2005 | 07:44 PM
Hey Mike I am going to call you tommorrow.I need to adjust the shift linkage in one of my engines.It pops out of revese sometimes and it needs adjustment.Do you know anything about it.I just need to adjust the throw on the cable a little.
Mark
fishead is offline
Old 05-22-2005 | 09:15 PM
Mark If you look at the shift linkage there is a netural mark where the cable connects. Center that mark put your control in netural and adjust the cable so it slides on, simple!
hirschlegal
09-28-2005 02:03 PM
hirschlegal
09-27-2005 12:41 AM
Hydro
07-31-2002 11:17 AM
