Two stage Eickert sea pump >
Old 05-22-2005 | 04:15 PM
CcanDo's Avatar
Default Two stage Eickert sea pump
Opinions are appreciated~the schematic starts with a one and one quarter inch pickup~to the sea strainer~to the pump~to a collector for both pump outlets~to the power steering cooler~to the transmission bell housing cooler~to a thirty two o eight caterpillar engine cooler~to the engine oil and transmission thermostats ~to a collector that splits the flow between both inlets on the Eickert crossover~out the one and one quarter inch outlets in the BDS intakes~to the CMI low cat headers~to dry tail pipes with a dump~the steam ports at the back of the intake go to the back of the header water log~we do not have inter coolers~I think I like the extra insurance from the dual impellers ~excess pressure or spikes will be dumped overboard with a pressure relief valve after the coolers but before the thermostats
CcanDo is offline
Old 05-22-2005 | 10:35 PM
Brad Zastrow's Avatar
Default Re: Two stage Eickert sea pump
A suggestion of having the pressure relief valve at the sea strainer instead. On my boat there is a seperate fitting on the strainer with a relief valve that will dump out the stern.
Brad Zastrow is online now
Old 05-23-2005 | 03:54 PM
If one pump looses an impeller you're gonna have to stop because it may clogg a cooler,just a thought...
Dixie Doug is offline
Old 05-23-2005 | 05:10 PM
I'm running the same pump as yours with similar routing, except using the bell housing coolers for engine and trans. Like Brad's, the sea strainers have a pressure relief valve at the top for pressure spikes. The spikes and steam ports dump over the side.
Dueclaws is offline
Little Tommy
0
07-23-2008 10:33 PM
masher44
16
08-19-2007 10:30 PM
baja27
6
12-29-2006 08:45 AM
customryder
2
03-12-2006 06:37 PM
Hiflier68
1
09-02-2003 01:04 PM
