HP 500 Ignition Module -failure >
Old 05-24-2005 | 08:42 AM
Ran-Dom 32's Avatar
Default HP 500 Ignition Module -failure
anyone have one of these ignition module's let go? '99 HP500's engine quit while cruising - no spark - swapped out box from SB engine & fired up? $200 bucks for a new one?? Was thinking of going with MSD but do I still need this ICM box #840130??
Ran-Dom 32 is offline
Old 05-24-2005 | 08:43 AM
Ran-Dom 32's Avatar
Default Re: HP 500 Ignition Module -failure
Is there a rev limiter built in to this component.
Old 05-24-2005 | 04:53 PM
Yes,
the rev limiter is built into the module,
.........and don't you just love where the
mercury engineers decided to mount it,
Never had a module go bad, but
lost a coil last year.
JaayTeee is offline
Old 05-24-2005 | 05:08 PM
KCHOTBOAT's Avatar
Charter Member #737
I bought a Crane box to replace mine. $270. from Summit.
KCHOTBOAT is offline
Old 05-24-2005 | 05:43 PM
tcelano's Avatar
I had faulty distributor module fail on my EFI motor when I got it. After I installed the motor, and tried to fire it for the first time, my pride and joy simply refused to generate any spark. After some troubleshooting, I eliminated the ignition coil and my FAST fuel injection computer as the culprits. The engine builder overnighted me a new distributor module. A 5-minute swap job later, and she roared to life. I ordered another spare ($90) and keep it with me...
tcelano is offline
Old 05-24-2005 | 07:54 PM
Ran-Dom 32's Avatar
Originally Posted by jt29olhp500s
Yes,
any idea what the rev limiter is set at stock ? '99 HP 500
Old 05-24-2005 | 09:54 PM
5350rpms or very close to it.
Griff is offline
Old 05-25-2005 | 06:52 AM
excursion's Avatar
Had the same thing happen to me TWICE on the same motor, make sure you change the coil, it will run for a while then when it gets hot it shorts out and will take out the module again, learned this last year the hard way. I now have the Thunderbolt IV ignition module, did away with the rev-limiter.
excursion is offline
Old 05-25-2005 | 08:02 AM
Ran-Dom 32's Avatar
I did notice oil residue around the coil - could this be the culprit which caused the problem?? My tachs read 5400-5500 @ WOT are they off? or have these boxes been changed/reprogrammed??
Old 05-25-2005 | 09:06 AM
Ran-Dom 32's Avatar
now I'm wondering if I've been against the rev limiter all this time & thats what fried the module???
