Prop for 24 Outlaw / 385HP ? >
Old 05-25-2005 | 07:32 AM
Wardey's Avatar
Default Prop for 24 Outlaw / 385HP ?
My buddy has a 1997 24 Outlaw with the 385HP / 454MPI and standard drive height. He is running a 21P Mirage 3 Blade and gets 62 mph at 4800rpm. Anyone played with other props on this boat / motor combo? We popped a 22 P Hydro 4 Blade and lost speed, tried a 23 P Mirage and no gains. The drive is at standard height from Baja. Thanks, Dave
Wardey is offline
Old 05-25-2005 | 10:11 AM
Smitty's Avatar
Default Re: Prop for 24 Outlaw / 385HP ?
I've got a 22" Mach sterndriver 4 blade that just might work for you. It was only used 2 times . I used to run a 26" sterndriver on my 95 24 Outlaw and it was by far the best all around prop on that boat.
Email me at [email protected] if you are interested.
Dave
Smitty is offline
Old 05-25-2005 | 06:13 PM
Hey Wardey,
I had the best results with Merc Rev 4 prop. The boat needs a little stern lift. Unfortunately the hull is not that efficient for speed. Matt & Julie may have a 19 & 21 Rev you could try.
Johno is offline
Old 05-26-2005 | 08:35 AM
Registered User
I know several guys that run that boat. Most of them run 24 bravo's some of them labbed. The mirage is a little faster but at the expense of handling and ride.
320es is offline
88242LS
12-26-2007 07:44 PM
zzzzzz
10
03-16-2006 08:43 PM
always wanted
17
03-24-2005 04:43 PM
Elite Marine
Pantera
4
04-28-2003 02:44 PM
timucin
3
04-10-2003 06:48 AM
