Raylar review - HotBoat Magazine
A couple of months ago HotBoat featured an install of the Raylar system. The next issue (I thought) was to review the on-water testing results. I now have the next issue, but no follow-on article. Is there one coming? Does anyone know what the outcome was of the testing?
So, now I have the next month's issue of HotBoat Mag. and the water-test results are still nowhere to be found - all discussion of Raylar results has been dead for a long while - what gives?
Logic says there is no way the stock 555 speed density ecu was factory programmed with 100+ extra hp worth of fuel.(Unless they are modifying the coolant temp and/or IAT signal)
I, too, await the on water results.
The Raylar kits goal is to flow more air, so the air mass sensor will signal to instruct the needed extra fuel (unless they remove the AM too)
