another day at jcperf engines >
Old 05-26-2005 | 09:50 PM
Default another day at jcperf engines
way to go!! better get another case of tape ,and some marine tex
open87 is offline
Old 05-26-2005 | 09:56 PM
glassdave's Avatar
Neno the mind boggler
Default Re: another day at jcperf engines
we've come to expect the here
08 OPA High Points Champion
glassdave is offline
Old 05-26-2005 | 10:30 PM
VelocityMark's Avatar
JB weld will fix that.
VelocityMark is offline
Old 05-26-2005 | 11:59 PM
SeaRay Jim's Avatar
"I think we can bore it a little more....." Oop's
SeaRay Jim is offline
Old 05-27-2005 | 12:06 AM
FOUNTAINATLAST's Avatar
Was masher able to avoid that rod, or did you finally get'em.
You'll still have the motor ready for the weekend right!!!
FOUNTAINATLAST is offline
Old 05-27-2005 | 12:11 AM
timewarp's Avatar
Talking Re: another day at jcperf engines
That'll Buff right out
timewarp is offline
Old 05-27-2005 | 12:40 AM
JCPERF's Avatar
Retard
JCPERF is offline
Old 05-27-2005 | 07:07 AM
Originally Posted by JCPERF
Retard
no f'n chit
open87 is offline
Old 05-27-2005 | 07:15 AM
Stormrider's Avatar
JC Performance Engines
Damn, I better be careful running this weekend!
Can I still get home on an engine like that?
Stormrider is offline
Old 05-27-2005 | 07:16 AM
Waterfoul's Avatar
Gone Fishin'
Originally Posted by Troutly
Why fix it? Just leave out the rod and piston in that cylinder. It'll run fine as a V-7
Ummm.... look at the other side... it's wiped out too!! That would make it a V-6!!
So if it was a 454, and you wiped out 2 cylinders, that would make it a.... carry the 4... divide by mashers IQ.... add JCPERF's shoe size.... subtract 69.... multiply by the coeficient of drag for a 46 Skater... and you have a 341ci motor.
Probably sound good with dry exhaust too!!
Waterfoul is offline
