Water Pressure Gauge >
Old 05-27-2005 | 12:48 PM
Default Water Pressure Gauge
I have room for one more gauge on my panel.
My rigger has suggested one to monitor water pressure.
Fred at Trick Marine thought the range of Zero to 35 psi was best, but admits he is not fully familiar with my application,
the 496 MagHO.
Other ranges choices are Zero to 9 psi and Zero to 90 psi.
Thanks for your help.
MyPetViper is offline
Old 05-27-2005 | 12:51 PM
Wally's Avatar
Were doomed!
Default Re: Water Pressure Gauge
Water psi youll need the 0-30 gauge........0-9 is not enough...... and if your doing more then 30 i'd be worried about poping gaskets as most engines dont like more then 20psi.....
-Wally
Wally is offline
Old 05-27-2005 | 04:18 PM
RLW
I agree.
If you're running more than 20-25 psig on an open system, it's time for a pressure relief device. With closed cooling, there shouldn't be as much of a concern. It really depends on how your system is designed and for what pressure. I am not familiar with the 496 closed cooling system.
RLW is offline
Old 05-27-2005 | 11:41 PM
hillbilly24's Avatar
The 496 will run about 2-3 PSI at idle and 22-28 at WOT teh 0-35 PSI is perfect, the increments on the 90PSI guage would be too large to be very usefull. Sound like Fred made a good educated guess.
hillbilly24 is offline
eliminatethis
5
06-29-2007 07:12 AM
MyPetViper
0
05-27-2005 12:34 PM
Sammy
4
12-29-2004 09:29 PM
treatcg
2
05-22-2003 09:26 AM
blackhawk
08-13-2002 12:44 AM
